Home > Technical (L405) > Vogue SE SDV8 non-starting issues
Toolbox
United Kingdom 2016 Range Rover Vogue SE SDV8 Santorini Black
Hi there new user here looking for any feedback on an issue I am having. Driving a Jan2016 Vogue SE SDV8
Two months ago I stopped the car while nipping into my parents house and on returning a couple of minutes later it would not restart. It tried to tick over but instantly shut down several times. Called out Landrover assist who where there within the hour and it started first time! Naturally the local garage couldn't do anything as the fault was not diagnosed and would not replicate.
Last week the same thing happened. I stopped car briefly to put letters in post box and it would not restart some 60 seconds later. This time thankfully it replicated the fault when landrover assist engineer arrived and he thought it was a sensor/valve relating to the manifold. As the car was on a main road and still not starting it was collected that evening and taken to dealership.
In the morning it started first time in the dealership and it would not replicate the issue over the three days they tested it. They said that if the fault does not happen in the dealership then they cannot replace parts on warranty. My issue is that as the Landrover assist engineer diagnosed the issue and said he would have replaced the sensor if he had had one in his van (he only had one for V6 engine), therefore they know what needs attention.
They are happy for me to drive again and wait until it breaks down so they can investigate at that time!
Anyone had a similar issue? If so what was the outcome?
Post #425978 2nd Feb 2017 1:04pm
Doodle
Tried your second key fob with first fob well away?
Post #425982 2nd Feb 2017 1:37pm
AndyS
Time to star getting firm with your dealer and also getting onto Land Rover. As you say they have diagnosed the problem so should accept responsibility and fix it and why should you be potentially left stranded again, it's done it twice now so more than likely to give up a gain. I'd be moaning rather vigorously if I were you.
Dealers are way too eager to get the car in and out of the workshops too quickly and not investigate issues. Too many fitters and not enough mechanics.
Post #425991 2nd Feb 2017 2:52pm
WillyT
United Kingdom 2017 Range Rover Vogue SE SDV8 Carpathian Grey
How long you had the car ?
Post #426001 2nd Feb 2017 3:58pm
Did it refuse to start, or start & immediately stop ?
I had an issue where mine would instantly stop - due to freezing - details here
Post #426005 2nd Feb 2017 4:41pm
JasM
Scotland 2014 Range Rover Autobiography SDV8 Santorini Black
Take a video of it when it happens again and show it to your dealer. 2014 SDV8 Autobiography Cool
Gone: 2012 RRS SDV6 HSE, 2007 RRS TDV6 HSE
Post #426080 3rd Feb 2017 12:24am
Toolbox
Thanks for your comments. I happened once with each key as it happens.
I do have a video of it happening and as it was diagnosed I am going to contact Landrover direct if they are truly not allowing the dealer to fix under warranty.
Post #426117 3rd Feb 2017 1:14pm
Toolbox
Thanks Alistair, it half turned over but never fully started.
Post #426118 3rd Feb 2017 1:16pm
Doodle
I am not sure of the receiver location, but if it's a case of the dash being removed, it's a job the dealers seem not to like doing on the 405.
If the fault is identified, it would seem your dealer is under an obligation to correct this. Hopefully LR will intervene on your behalf. Interesting to see how it develops.
Post #426128 3rd Feb 2017 2:53pm
Dixy
2016 Range Rover Vogue SDV8 Loire Blue
Under the customer rights act/ sale of goods act you have a right to repair, replacement or refund, as they have declined the first ask which of the others they have chosen. Should focus the mind a tad. letters not necessarily in the right order
Post #426218 4th Feb 2017 10:34am
neo
England 2013 Range Rover Vogue SDV8 Santorini Black
Did LRA run diagnostics and check for stored DTCs? I would expect that some for fault code would have been logged?
Post #426821 8th Feb 2017 12:49am
jumpin mouse
United Kingdom 2015 Range Rover Autobiography SDV8 Aruba
I've just seen this. My MY2015 4.4 SDV8 wouldn't start on two occasions after I bought it 3 weeks ago. It turned over fine and if left for a few minutes would appear to fire and nearly start.
LR Assistance came out and diagnosed a sticking air shut-off valve (silver thing at the front of the engine in the centre, high up). He took it off, cleaned the gunge inside and it has worked ever since. My car had hardly been used for a few months prior to me buying it, just moved around at the dealers and short test drives. To quote the technician: "I've had them like this before, I'm 90% sure that's your problem". It has started every time since.
Post #428033 16th Feb 2017 10:26pm
