Home > Technical (L405) > Vogue SE SDV8 non-starting issues |
Doodle Member Since: 02 Nov 2013 Location: Midlands Posts: 127 |
Tried your second key fob with first fob well away? |
2nd Feb 2017 1:37pm |
AndyS Member Since: 27 Feb 2016 Location: Lymington, Hampshire Posts: 395 |
Time to star getting firm with your dealer and also getting onto Land Rover. As you say they have diagnosed the problem so should accept responsibility and fix it and why should you be potentially left stranded again, it's done it twice now so more than likely to give up a gain. I'd be moaning rather vigorously if I were you.
2nd Feb 2017 2:52pm |
WillyT Member Since: 12 Aug 2016 Location: UK Posts: 90 |
How long you had the car ? |
2nd Feb 2017 3:58pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7797 |
Did it refuse to start, or start & immediately stop ?
2nd Feb 2017 4:41pm |
JasM Member Since: 08 May 2015 Location: Lanarkshire Posts: 220 |
Take a video of it when it happens again and show it to your dealer. 2014 SDV8 Autobiography
3rd Feb 2017 12:24am |
Toolbox Member Since: 02 Feb 2017 Location: Aberdeen Posts: 3 |
Thanks for your comments. I happened once with each key as it happens.
3rd Feb 2017 1:14pm |
Thanks Alistair, it half turned over but never fully started.
3rd Feb 2017 1:16pm |
I am not sure of the receiver location, but if it's a case of the dash being removed, it's a job the dealers seem not to like doing on the 405.
3rd Feb 2017 2:53pm |
Dixy Member Since: 09 Apr 2009 Location: Somerset Posts: 1075 |
Under the customer rights act/ sale of goods act you have a right to repair, replacement or refund, as they have declined the first ask which of the others they have chosen. Should focus the mind a tad. letters not necessarily in the right order |
4th Feb 2017 10:34am |
neo Member Since: 23 Aug 2009 Location: Trapped in the Matrix Posts: 87 |
Did LRA run diagnostics and check for stored DTCs? I would expect that some for fault code would have been logged? |
8th Feb 2017 12:49am |
jumpin mouse Member Since: 28 Feb 2016 Location: North West Posts: 222 |
I've just seen this. My MY2015 4.4 SDV8 wouldn't start on two occasions after I bought it 3 weeks ago. It turned over fine and if left for a few minutes would appear to fire and nearly start.
16th Feb 2017 10:26pm |
