![]() | Home > Technical (L322) > Fbh followed by a flat battery........... |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35684 ![]() ![]() |
its testing times for our batteries at the moment...3 years is beginning to be on the borderline..i'd change it and not any risks.. ... - .- -.
3 Years is about the limit for a battery. Also you generally get 3 or 4 deep discharges out of a battery before it's goosed. Even on a new oone as it destroys the plates inside.
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 ![]() ![]() |
Cheers guys, I'll try it again with the fbh over the coming days. If/when it fails I'll call lr assist n let them recommend a new battery for the warranty. Ian |
Battery now 5 and a half year old ........... |
it'll be flat tomorrow mick... |
Sportex Member Since: 12 Jun 2010 Location: Up North Posts: 366 ![]() ![]() ![]() |
Just gone through the same, 3 year old battery, -12C, FBH in am, flat battery, not only flat but naker'd. £140 and new battery everything ok again |
I've never had a battery fail at 3 years, are they not as good as they used to be?
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2617 ![]() ![]() |
Exactly the same problem - two and a half years old, completely flat again this week (for about the fourth time) after using the FBH.
dantheman Member Since: 02 Feb 2009 Location: North: Lancs Posts: 477 ![]() ![]() |
3 years should not herald the end of life for a battery... mine is still using the original battery (almost 5 1/2 yrs old and showing no signs of giving up the ghost at all - totally unaffected by the cold). I also had the original battery on my Alfa Romeo when I came to sell it after 8 1/2 yrs. If anyone's battery is giving up the ghost at around the 2-3 yr point I would urge them to investigate further IMHO. |
But this completely depends on how your battery is treated. After 3 years it is assumed you've generally had a couple of deep discharges - from leaving lights on, or from month long holidays (or more than likely laid up for 6 weeks in the dealer). It's the deep discharges that kill the battery, whether you do 1 a year or 3 in a month etc. It's also worth noting that the battery in the RR is quite a small unit for the size of car and electrical load - compared to a "normal" car. Every car is different too, in respect to the type of journeys it does - lights, seats screen on etc? ![]() |
The dealer has told me that the battery is in good condition, "It just needs a good overnight charge". I detect the smell of b |
Paul J. Member Since: 13 Jan 2009 Location: Leafy Cheshire Posts: 280 ![]() ![]() |
The repeated combination of FBH use and short journeys will drain even a good battery. Unfortunately the low voltage detector does not do a very good job of shutting off the drain before the FBH (well actually the fans) deplete the battery beyond the point where it will start the engine.
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6374 ![]() ![]() ![]() |
There are too many factors at play to generalise about when your battery should die.
Its back today, i think i may adopt the optimate through the towbar electric route whilst sat on the drive. Ian |
