![]() | Home > Technical (L322) > Fbh followed by a flat battery........... |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35879
its testing times for our batteries at the moment...3 years is beginning to be on the borderline..i'd change it and not any risks.. ... - .- -.
| dan_uk_1984 Member Since: 12 Nov 2008 Location: Bude, Cornwall Posts: 4014
3 Years is about the limit for a battery. Also you generally get 3 or 4 deep discharges out of a battery before it's goosed. Even on a new oone as it destroys the plates inside.
| T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936
Cheers guys, I'll try it again with the fbh over the coming days. If/when it fails I'll call lr assist n let them recommend a new battery for the warranty. Ian |
| JOKER Member Since: 11 Sep 2008 Location: Sconnie Botland Posts: 15876
Battery now 5 and a half year old ........... |
it'll be flat tomorrow mick... |
| Sportex Member Since: 12 Jun 2010 Location: Up North Posts: 366
Just gone through the same, 3 year old battery, -12C, FBH in am, flat battery, not only flat but naker'd. £140 and new battery everything ok again |
| 47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048
I've never had a battery fail at 3 years, are they not as good as they used to be?
| Philip Member Since: 05 Jan 2010 Location: UK Posts: 2626
Exactly the same problem - two and a half years old, completely flat again this week (for about the fourth time) after using the FBH.
| dantheman Member Since: 02 Feb 2009 Location: North: Lancs Posts: 477
3 years should not herald the end of life for a battery... mine is still using the original battery (almost 5 1/2 yrs old and showing no signs of giving up the ghost at all - totally unaffected by the cold). I also had the original battery on my Alfa Romeo when I came to sell it after 8 1/2 yrs. If anyone's battery is giving up the ghost at around the 2-3 yr point I would urge them to investigate further IMHO. |
But this completely depends on how your battery is treated. After 3 years it is assumed you've generally had a couple of deep discharges - from leaving lights on, or from month long holidays (or more than likely laid up for 6 weeks in the dealer). It's the deep discharges that kill the battery, whether you do 1 a year or 3 in a month etc. It's also worth noting that the battery in the RR is quite a small unit for the size of car and electrical load - compared to a "normal" car. Every car is different too, in respect to the type of journeys it does - lights, seats screen on etc?
The dealer has told me that the battery is in good condition, "It just needs a good overnight charge". I detect the smell of b |
| Paul J. Member Since: 13 Jan 2009 Location: Leafy Cheshire Posts: 280
The repeated combination of FBH use and short journeys will drain even a good battery. Unfortunately the low voltage detector does not do a very good job of shutting off the drain before the FBH (well actually the fans) deplete the battery beyond the point where it will start the engine.
| RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6383
There are too many factors at play to generalise about when your battery should die.
Its back today, i think i may adopt the optimate through the towbar electric route whilst sat on the drive. Ian |
| All times are GMT |
