![]() | Home > In Car Electronics (L322) > Intravee .. wrong connector |
chris_read Member Since: 26 Feb 2012 Location: Louth, Lincolnshire Posts: 474 ![]() ![]() ![]() |
It really isn't that difficult to do. I managed to find the two connectors (6 pin and 3 pin) in the boot of a BMW at the local scrapyard. They charged me £1!
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 ![]() ![]() ![]() |
Yeah I'm having the same issue trying to track connectors down.. thanks for heads up! |
The ibus connection fits .. just the audio part I need..
Rewmer Member Since: 14 Jan 2013 Location: Essex Posts: 142 ![]() ![]() |
I've got details of how to swap the pins. It's very easy. I bought the two plugs from an X5. All the pins are numbered, just follow the guide.
Thanks matey.. just ordered there last set |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
Those plugs are readily available on the bay of fleas.. do a search for "CD plugs" BMW, MG, Rover, Range Rover etc |
That's a great help. Thanks buddy! I presume the other connector I unplugged which actually fits in the ibus connection to the intravee should just be plugged back in and ignored? |
Yes I will dig out the pin relocation info when I get back to my home pc No7 - 2003 V8 Vogue |
Follow this .......................
Thanks my good man.. quite looking forward to this now.. managed to fit b####d 2012 rear leds (eventually) and even managed to rid the units of a permenant half on foggy so this should be a doddle with your list.. |
I found that the pins came out of the plug easily, the tricky bit is getting the plug inner out of the outer |
Well that's it finally fitted. Quite enjoyed the re-pinning part tbh . It doesn't look too organised in there but I've managed to tuck about 40 foot of cable through the small gaps at the roof of the glove box.
Also very important to use the earths.. tried it without just to see and the TV keeps switching off and on.. keeps grounding and the system doesn't work as it should.. added the earths and it's perfect! |
