Home > In Car Electronics (L322) > Intravee .. wrong connector
alistairh
Ripped out the my glovebox and just my luck I have the wrong connector for my intravee..I've seen the post regarding swapping the connector with the appropriate fitting but I'm gurenteed to mess that up Laughing does anybody know of a connector between the current connector and the intravee? thanks
Post #426271 4th Feb 2017 5:52pm
chris_read
England 2009 Range Rover Vogue TDV8 Stornoway Grey
It really isn't that difficult to do. I managed to find the two connectors (6 pin and 3 pin) in the boot of a BMW at the local scrapyard. They charged me £1!
I spent ages looking for a ready made connector harness as mentioned here - http://www.fullfatrr.com/forum/post264562.html
But they were nowhere to be found..... Sad
Post #426277 4th Feb 2017 6:32pm
alistairh
Yeah I'm having the same issue trying to track connectors down.. thanks for heads up! Thumbs Up
Post #426279 4th Feb 2017 6:56pm
alistairh
The ibus connection fits .. just the audio part I need..
Post #426280 4th Feb 2017 7:07pm
Rewmer
I've got details of how to swap the pins. It's very easy. I bought the two plugs from an X5. All the pins are numbered, just follow the guide.
These are the plugs. http://www.ebay.co.uk/itm/BMW-E46-E39-X5-E...Sw8w1X6B4H No7 - 2003 V8 Vogue
Post #426284 4th Feb 2017 7:53pm
alistairh
Thanks matey.. just ordered there last set Thumbs Up ..
Post #426290 4th Feb 2017 8:16pm
miggit
Those plugs are readily available on the bay of fleas.. do a search for "CD plugs" BMW, MG, Rover, Range Rover etc Thumbs Up
Info here on the correct wire / pin locations http://www.fullfatrr.com/forum/topic26808.html?highlight=10+pin
Whistle there were a lot of posts on how to leave X amount of wires in the old plug, I found all the correct positions for all wires Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #426291 4th Feb 2017 8:20pm
alistairh
That's a great help. Thanks buddy! I presume the other connector I unplugged which actually fits in the ibus connection to the intravee should just be plugged back in and ignored?
Post #426309 4th Feb 2017 9:47pm
Rewmer
Yes I will dig out the pin relocation info when I get back to my home pc No7 - 2003 V8 Vogue
Post #426319 4th Feb 2017 10:29pm
Rewmer
Follow this .......................
Move pin 1 (on 10-pin connector) to pin 4 on 6-pin connector (white/blue)
Move pin 2 to pin 2 on 6-pin connector (white/brown)
Move pin 3 to pin 1 on 3-pin connector (brown)
Pin 4 is not connected
Move pin 5 to pin 3 on 3-pin connector (white/grey/yellow)
Move pin 6 to pin 1 on 6-pin connector (white/red)
Leave pin 7 - not needed (white/brown)
Leave pin 8 - not needed (brown)
Pin 9 is not connected
Move pin 10 to pin 2 on 3-pin connector (red/green) No7 - 2003 V8 Vogue
Post #426328 4th Feb 2017 11:29pm
miggit
Whistle Yup and there we have it..... earth wires left behind..... if they weren't needed then BMW / LR wouldn't have put them there in the first place and saved a few miles of cable in the process Rolling Eyes
alistairh, buddy you have the list Wink , and yes you are correct in thinking that you don't need it move the 3 pin wires are they are already present in the connection that unplugs from the 10 pin loom Thumbs Up
So to recap, you need to transfer the wires / pins from the 10 pin plug to the 6 pin and use the already wired 3 pin plug that's in the loom Mr. Green Yesterday I couldn't spell Engineer... Today I are one!
Post #426379 5th Feb 2017 12:14pm
alistairh
Thanks my good man.. quite looking forward to this now.. managed to fit b####d 2012 rear leds (eventually) and even managed to rid the units of a permenant half on foggy so this should be a doddle with your list.. Thumbs Up
Post #426388 5th Feb 2017 12:52pm
miggit
I found that the pins came out of the plug easily, the tricky bit is getting the plug inner out of the outer Shocked Don't give up, and a selection of small (jewelers) screwdrivers is a big help Thumbs Up
Also I'd be inclined to remove the 10 pin wires first... say practice on the 3 wires from the 3 pin plug / socket a few inches up the loom... that way if you cock it up, there's no foul as they aren't required Rolling Eyes Once you've mastered the removal of the 3 unused connections you'll be in a good place to transfer the pins 1 at a time to the 6 pin plug Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #426392 5th Feb 2017 1:01pm
alistairh
Well that's it finally fitted. Quite enjoyed the re-pinning part tbh . It doesn't look too organised in there but I've managed to tuck about 40 foot of cable through the small gaps at the roof of the glove box.
Nearly spat the dummy out at one point when it was all wired up and it wouldn't switch on..I had forgotten to put the fuse back Laughing ..thanks again guys for the pointers..
Post #427079 9th Feb 2017 7:06pm
alistairh
Also very important to use the earths.. tried it without just to see and the TV keeps switching off and on.. keeps grounding and the system doesn't work as it should.. added the earths and it's perfect!
Post #427111 9th Feb 2017 11:25pm
