![]() | Home > Maintenance & Mods (L322) > Quick question on EGR blanking. |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 ![]() ![]() ![]() |
Yes you need to blank the vacuum pipe, that is whst operates the egr.
hamlet Member Since: 18 Nov 2016 Location: Kildare Posts: 294 ![]() ![]() ![]() |
Thanks for that Greg, I just didn't want to throw up any errors since it's actually physically blanked already I though the operation of the valve wouldn't matter but if the consensus is to blank the vacuum then that's certainly not difficult to do.
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3984 ![]() ![]() ![]() |
You can just screw a brass woodscrew into the end of the vacuum pipe and cable tie it out of the way.
lounge_on_wheels Member Since: 10 Dec 2016 Location: in the great land of oz Posts: 269 ![]() ![]() ![]() |
I fitted a blanking kit and now have this error
I fitted a blanking kit and now have this error (2003 TD6)
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 807 ![]() ![]() ![]() |
I would check to see if the vacuum hose is properly blocked or has a leak somewhere. It should not cause any issues if the EGR is removed and the hose capped. 2007 TDV8 VSE
That fault I'm sure, always comes up with my iid.
Never had it with mine. |
Does yours come up since your blanked the egr? When you say that code always comes up. |
Did you just blank the exhaust side of the egr or fit a EGR delete unit. That code has something to do with airflow and linked with Maf settings according to the BMW forums 2007 TDV8 VSE
The egr was already blanked when I bought the car.
Have you seen this thread? http://www.fullfatrr.com/forum/post396601.html 2007 TDV8 VSE 2003 TD6 gone. 2002 P38a gone 1999 P38a gone 1997 p38a gone 1993 VSE gone 1992 VSE gone 1966 Series 2a with V8 conversion gone |
Yes, I read that and no it is not the cause as I replaced those hoses and it did not fix the problem. |
MattyB1983 Member Since: 05 Feb 2017 Location: Cambridge Posts: 81 ![]() ![]() ![]() |
Sorry to jump in but just been out to my car for a look to see if mine had been done prior to me purchasing the car....
