![]() | Home > Technical (L322) > Fuel burning heater..... |
Mikeinatruck Member Since: 14 Apr 2016 Location: Dumfries Posts: 50 ![]() ![]() ![]() |
They come on to speed heat the interior so it'll take a while to heat up if you pull the fuse. They tend to smoke because they don't get a lot of use
MattyB1983 Member Since: 05 Feb 2017 Location: Cambridge Posts: 81 ![]() ![]() ![]() |
It's been cold alot lately so it's been kicking in every morning, and smokes everytime |
I think there is a timed climate setting in the dash display. So you can use it when parked and not have the engine running. You can also set a time for it to come on. 2018 L405 Autobiograpghy
Yep I've seen that on the screen, it's says 'auxiliary ventilation '....... is that the FBH then chap ??? |
I think so. Have a play with it. Should have two time settings. But if the engine is not run in a 24 hour period it won't work. Saves to battery going flat 2018 L405 Autobiograpghy
I'll give it a whirl at the weekend and see how it goes... is it worth running some injector cleaner through the fuel tank do you think ??? |
Wont do at harm... 2018 L405 Autobiograpghy
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3241 ![]() ![]() ![]() |
Aux ventilation is for hot weather.
Ummmmm..... Can't say I've seen 'aux heating' on my screen to be honest, just 'auxiliary ventilation " |
mike whiskey Member Since: 11 May 2015 Location: Huntingdon Posts: 115 ![]() ![]() ![]() |
If it's not there then it can be enabled using IID or similar.
vmaxer Member Since: 22 Jun 2016 Location: staffs Posts: 110 ![]() ![]() ![]() |
wish mine would smoke then id now its working |
