Home > Technical (L322) > Fuel burning heater.....
MattyB1983
United Kingdom 2004 Range Rover Vogue SE Td6 Java Black
So I've seen loads of threads on here about them and it's obviously a very common thing to give grief...
Mine, as do most it would seem, smokes like Censored occasionally and I find it quite embarrassing. This week in the drive through queue for instance, I was actaully asked if my car was on fire Laughing
Every thread I've read regarding smoking FBH's gets the reply that it's totally normal and nothing to worry about.... but they shouldn't smoke, they didn't when new for instance. So why do they do it and has anybody cured it...?? If it's not going to cost me a small mortgage to rectify then I'll certainly do it, just to avoid the embarrassment again... Laughing
Or.... something I thought of earlier.... would simply pulling out the fuse cause any harm... I'm sure I can do without it, no other car I've owned has had one anyway...
Cheers guys,
Matt.
Post #426638 6th Feb 2017 10:10pm
Mikeinatruck
United Kingdom 2018 Range Rover Autobiography SDV6 Santorini Black
They come on to speed heat the interior so it'll take a while to heat up if you pull the fuse. They tend to smoke because they don't get a lot of use
So carbon up a bit. I would put a battery charger on it and run the fbh a couple of full cycles if you have a remote or stick it on manual.
Post #426650 6th Feb 2017 11:10pm
MattyB1983
It's been cold alot lately so it's been kicking in every morning, and smokes everytime Big Cry
I've read that later models have a remote but my car is only a 2004 so doesn't have one, and I've not seen anyway of manually turning it on... it just seems to fire up when around 3 degrees outside.
Post #426655 6th Feb 2017 11:31pm
Mikeinatruck
I think there is a timed climate setting in the dash display. So you can use it when parked and not have the engine running. You can also set a time for it to come on. 2018 L405 Autobiograpghy
Post #426658 6th Feb 2017 11:42pm
MattyB1983
Yep I've seen that on the screen, it's says 'auxiliary ventilation '....... is that the FBH then chap ???
Post #426659 6th Feb 2017 11:47pm
Mikeinatruck
I think so. Have a play with it. Should have two time settings. But if the engine is not run in a 24 hour period it won't work. Saves to battery going flat 2018 L405 Autobiograpghy
Post #426662 6th Feb 2017 11:54pm
MattyB1983
I'll give it a whirl at the weekend and see how it goes... is it worth running some injector cleaner through the fuel tank do you think ???
Post #426795 7th Feb 2017 10:14pm
Mikeinatruck
Wont do at harm... 2018 L405 Autobiograpghy
Post #426799 7th Feb 2017 10:23pm
Dolphinboy
Aux ventilation is for hot weather.
The option you want to use on your screen is the aux heating I believe?
Post #426800 7th Feb 2017 10:31pm
MattyB1983
Ummmmm..... Can't say I've seen 'aux heating' on my screen to be honest, just 'auxiliary ventilation "
Post #426801 7th Feb 2017 10:34pm
mike whiskey
United Kingdom 2006 Range Rover Vogue 4.4 V8 Buckingham Blue
If it's not there then it can be enabled using IID or similar.
MW Car history includes: LR Series 3, RR Classic x 4, LR 101, Discovery 1 and 2, FFRR. D3, Freelander 2 and now back in FFRR.
Yes I'm a masochist....
Post #426846 8th Feb 2017 10:56am
vmaxer
United Kingdom 2003 Range Rover Autobiography Td6 Cairns Blue
fbh
wish mine would smoke then id now its working Rolling Eyes tried direct on aux heating and put it on timed nowt :cry:got the basic iid but thats got no test for my year 2003
Post #426867 8th Feb 2017 1:03pm
