![]() | Home > Technical (L322) > Heating Transmission |
| Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3285
The bottom of the radiator which I believe operates the transmission cooler is known to get blocked up with sludge and debris. Either flush your radiator or get a new one. The oil cooler could also be the culprit ? |
| Rangeyman Member Since: 03 Feb 2015 Location: west yorkshire Posts: 267
Check any service history for new parts but unless they have been changed recently you need a new radiator and transmission cooler as they get blocked,you also need transmission oil as it deteriorates.there is plenty of info on this site about it . |
| b348xyx Member Since: 29 Sep 2016 Location: Kent Posts: 319
As both people said before, new radiator and gearbox cooler.
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8826
Within the plastic manifold that the gearbox oil cooler attaches (which is on the left hand side of the main radiator when viewed looking into the engine bay) is a separate thermostat for the oil cooler, this can get blocked of break as well so it's best to change the whole lot, also the oil cooler pipes back to the transmission can delaminate and collapse preventing the oil from getting cooled.. If you can afford it it's best to change the lot, if not, take it all out and give it a good looking at and cleaning. It is virtually impossible to clean out the main engine radiator or oil cooler well enough to make any difference...
| holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086
The cooling strategy is the reason it won't let you change up as it is trying to pump the oil around the cooler faster. I changed everything above when I rebuilt my transmission apart from my radiator as when I flushed it through it was nice and clear. I kept all my old parts except the pipes as they had to be cut off if you want a photo of any of it. What sort of temperature was it when it started hanging onto gears and what budget are you working to? |
| All times are GMT |
