![]() | Home > Maintenance & Mods (L322) > Engine Cutting Out Intermittently - 2012 4.4 TDV8 |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3827 ![]() ![]() ![]() |
bwelton Member Since: 26 May 2014 Location: Milton Keynes Posts: 140 ![]() ![]() ![]() |
There are 2 x Manifold Absolute Pressure monitors
proser Member Since: 20 Jul 2015 Location: Stafford Posts: 452 ![]() ![]() ![]() |
We're those values taken at idle or driving.
Hi there,
It is not likely to be a live feed earthing, surely this would blow a fuse eventually and hence not be an intermittent fault, so much more likely to be a high resistance earth connection. G reg 2.5VM Vogue Portofino red 1991- 1999
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2671 ![]() ![]() |
The fuses are on the 12V supply, not the 5V supplies which typically are current limited by circuitry to 1A or 5A. |
OK. I have a log of an Engine Cut out whilst at idle.
Ok - I have captured a Failed Starting of the Engine followed by a Start of the engine.
I'm sure that the lack of a crankshaft position sensor is the reason why the engine falters, stops and wont start. The reason the the lack of signal will have to be investigated. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
My money is on the crank position sensor.
I expect the sensor / trigger to be the same setup as the TDV6 which uses the same sensor part number. The TDV6 trigger ring is pressed onto the crankshaft and the sensor pokes in deep from the side of the block and is retained by a single bolt. The sensor part number has been superseded twice since the 2011/2012 production version. The TDV8 sensor is mounted on the RHS of the block whereas the TDV6's is mounted on the LHS. |
Yes, I think its time to get the Crankshaft Position Sensor (LR049872) replaced.
KRAMSNEHPETS Member Since: 12 Mar 2017 Location: Herfordshire Posts: 3 ![]() ![]() ![]() |
has your car been fixed, noticed my car did the same today several time when driving, a second or 2 of what felt like no power no dash light come on though |
SOLVED |
