Home > Technical (L322) > Retractable Steps
Realist
Wales
Retractable Steps
Hi all,
One of out retractable steps (Passenger side) refuses to go back in, I can see its trying to retract but clicks then stays out, the drivers side is fine.
Any ideas where to start in finding out what the issue is or is their a way to keep both steps out so the car looks even.
Regards Range Rover quotes.....
The Luxury That�s More Than a Luxury.
Conquer the world, and look good doing it.
Built for the unexpected.
Over prepared, but never underdressed.
2007 Vogue SE TDV8 Epsom Green (old car).
2010 Discovery 3.0L GS Mk4 Black.
Post #427659 13th Feb 2017 11:23pm
JAYBOY
Have you greased them. Mine used to do it from time to time. I would give them a good soaking with WD40 or similar and then spray grease worked every time. 2020 Porsche Panamera Turbo Hybrid (V FAST)
2018 JCW Mini Cooper
2018 Skoda VRS
Post #427663 13th Feb 2017 11:50pm
Realist
Wales
Yep greased like hell and back just clicks a little twinge and stays out. Range Rover quotes.....
Post #427668 14th Feb 2017 1:20am
There is a reason they are called Deplorable side steps Laughing Shocked 2008 MY Supercharged
Post #427669 14th Feb 2017 1:43am
Realist
Wales
Yeh tell me about it.
I can see the motor trying to move but the step stays out so I'll disconnect it from the motor if I can and then test the motor then see if I can manually move the step. Range Rover quotes.....
Post #427735 14th Feb 2017 5:11pm
Mr Tee
Scotland 2019 Range Rover SVAutobiography 5.0 SC V8 Waitomo Grey
They work via a solenoid, it might be seized.
Post #427744 14th Feb 2017 5:41pm
andygts
http://www.ford-trucks.com/forums/963994-r...oblem.html
plenty of pics in this thread that might help you. Current
2017 Range Rover Sport SVR
2001 Porsche 911 Turbo
_____________________________________
Previous
2013 Range Rover Autobiography SDV8
2007 Range Rover Vogue SE TDV8
2002 Range Rover HSE TD6
+ Many other non LR products
Post #427782 14th Feb 2017 9:00pm
Realist
Wales
Thanks M8 will see what goes on my next day off.
Thanks. Range Rover quotes.....
Post #427816 14th Feb 2017 11:37pm
