![]() | Home > Technical (L322) > Retractable Steps |
Realist Member Since: 13 Feb 2016 Location: Wales Posts: 436 ![]() ![]() |
Hi all,
JAYBOY Member Since: 17 Oct 2012 Location: South Wales Posts: 2204 ![]() ![]() ![]() |
Have you greased them. Mine used to do it from time to time. I would give them a good soaking with WD40 or similar and then spray grease worked every time. 2020 Porsche Panamera Turbo Hybrid (V FAST)
Yep greased like hell and back just clicks a little twinge and stays out. Range Rover quotes.....
There is a reason they are called Deplorable side steps |
Yeh tell me about it.
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2718 ![]() ![]() ![]() |
They work via a solenoid, it might be seized. |
andygts Member Since: 16 May 2015 Location: Yorkshire Posts: 366 ![]() ![]() |
http://www.ford-trucks.com/forums/963994-r...oblem.html
Thanks M8 will see what goes on my next day off.
