![]() | Home > Technical (L322) > Ghosts in the machine? |
Reset your computer to zero and see how it goes from there |
topgeartowers Member Since: 23 Mar 2010 Location: London Posts: 82 ![]() |
I have reset the trip, both A and B, separately and together, and it still remains low. If I reset on a gentle run, even throttle 25mpg will pop up, but it soon slips back to 13. |
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1055 ![]() ![]() |
That seems really low. Mine shows 17-18, but actually is 12-13 (runs on lpg).
Jem0911 Member Since: 07 Jan 2010 Location: East Northants Posts: 357 ![]() ![]() ![]() |
I had a similar occurance this summer.
bogie Member Since: 06 Nov 2010 Location: Notts/Sth Yorks/Lincs border Posts: 208 ![]() ![]() ![]() |
have you checked the temp guage when its warmed up? is it 1/2 way as normal?
hi mate, what dealers did you go to, just so others know...
The temp needle never budged from the middle once before or after, I only took it in because the car bonged at me. I'll leave the dealership name out of it until I get a chance to speak to them tomorrow and fully understand what's going on. For all I know it may be usual when flushing the coolant to need to top it up after a few miles.
DeltaC Member Since: 23 Mar 2010 Location: Aberdeenshire Posts: 148 ![]() ![]() ![]() |
I'd have a look around to see if they've left an electrical connection off. There are a couple on the offside of the rad cowling and a water temp one on one of the hoses to the right, abouthalr way down. Might be that a missing connection is making the ECU think the engine is cold so it's giving it too much fuel... |
hi i am not shy in saying that stratstones in hainault/woodford nearly took me for 1400 pounds on a suspension problem that turned out to be the brake pads, never the less they blamed it on to an inexperienced technician, they also said it needed new sus bushes in the rear and it never, it needed a new oil filter housing when it was just the seal, and after all that charged me 15 pounds for a cable tie. |
Thanks to everyone who read and replied, took the Rangie in today and they quickly diagnosed an air pocket in the cooling system, flushed it once again and the problem was solved. I mentioned the low mpg problem, to which I was met with blank stares, however 3miles from the dealership on the way home and all was back to normal, with the trip reading an instant 25mpg, before settling down to the average 18mpg I'm used to in central London.
An air pocket around one of the water temp sensors would make it think the engine was cold, thus give it more fuel. |
