![]() | Home > In Car Electronics (L322) > Reversing Camera - Black Screen of death |
| miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3669
Try these!!
| Andy B Member Since: 03 Apr 2012 Location: West Malling Posts: 1223
Cheers Chap, some useful advice here |
| n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754
Mine is a 2007 and following the Wiki along with some testing and a voltmeter I fitted an ebay special and its a much better camera than the original !! Is this where I put the car details and a bit about myself ?........ |
Noticed that the camera's on a couple of loan cars I've had (Ewok, Disco Sport) are alot better as well. Decided to give the old girl a bit of a spruce up before investigating further |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35880
agreed, not only the cameras but the viewing screens are higher resolution.. ... - .- -.
Right, checked the camera via the 753 hack and it seems to be defaulting to PAL. When I change to NTSC and go back to the menu and back in again, it defaults back to PAL. Grrr.... Connected up the IID BT and can get to the menu where it says a rear camera is fitted, but not to any meaningful screen where I could change the setting.
| Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3276
Has the camera been changed at some time? It should be NTSC only, not NTSC/PAL or PAL. The symptoms you are describing with the 753 hack when trying to change to NTSC are similar to what happens when an NTSC/PAL or PAL camera have been installed. John
Cheers Chaps, I think a replacement from Fleabay is on the cards. I'll have a closer look tomorrow for anything obviously not right |
No mate, it just decided to stop working....it is a Range Rover after all! SDV8 VSE MY 2015 - Gone 5.0 S/C AB MY 2010 - Gone 4.2 S/C VSE MY 2006 - Gone |
Cheers for trying to find out |
| All times are GMT |
