Home > In Car Electronics (L322) > Reversing Camera - Black Screen of death
Andy B
Seen quite a few posts about the reversing camera going kaput and a great write up in the WIKI for replacing it. But I think these were on earlier L322 models. Mine is a 2010MY.
Screen just goes black when car is in reverse. Checked the fuse, which is fine. Tried the 753 hack and TV/DVD works fine, but reverse cam still has a black screen. Can anyone advise next steps please, Battery reset? IID check? Remove the spoiler and hit the camera with a large hammer? Very Happy
Cheers,
Andy SDV8 AB MY 2019
SDV8 VSE MY 2015 - Gone
5.0 S/C AB MY 2010 - Gone
4.2 S/C VSE MY 2006 - Gone
Post #428133 17th Feb 2017 5:44pm
miggit
Try these!!
http://www.fullfatrr.com/forum/topic11302.html?highlight=camera
http://www.fullfatrr.com/forum/topic39592.html?highlight=camera
And remember that the system uses NTSC camera's only... not NTSC/Pal or Pal Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #428156 17th Feb 2017 7:40pm
Andy B
Cheers Chap, some useful advice here Thumbs Up Bow down SDV8 AB MY 2019
Post #428219 18th Feb 2017 10:50am
n1cktdv8
Mine is a 2007 and following the Wiki along with some testing and a voltmeter I fitted an ebay special and its a much better camera than the original !! Is this where I put the car details and a bit about myself ?........
Post #428228 18th Feb 2017 12:30pm
Andy B
Noticed that the camera's on a couple of loan cars I've had (Ewok, Disco Sport) are alot better as well. Decided to give the old girl a bit of a spruce up before investigating further Very Happy
 SDV8 AB MY 2019
Post #428256 18th Feb 2017 4:11pm
agreed, not only the cameras but the viewing screens are higher resolution.. ... - .- -.
Post #428257 18th Feb 2017 4:13pm
miggit
Whistle unfortunately the Range Rover was the flagship in the line up, and it got all the toys long before the rest of the range did.. so the ffrr is a fault finding exercise for the rest of the LR product range... unfortunately LR have a strange philosophy.. if it ain't broke don't fix it... if it is broke fix begrudgingly.. and if it can be improved, save it for another model Laughing Yesterday I couldn't spell Engineer... Today I are one!
Post #428259 18th Feb 2017 4:18pm
Andy B
Right, checked the camera via the 753 hack and it seems to be defaulting to PAL. When I change to NTSC and go back to the menu and back in again, it defaults back to PAL. Grrr.... Connected up the IID BT and can get to the menu where it says a rear camera is fitted, but not to any meaningful screen where I could change the setting.
Does anyone know if it is possible to config the rear camera with the IID or change the setting via the 753 hack? Confused
Thanks in advance Thumbs Up SDV8 AB MY 2019
Post #428264 18th Feb 2017 5:00pm
Weegie
Has the camera been changed at some time? It should be NTSC only, not NTSC/PAL or PAL. The symptoms you are describing with the 753 hack when trying to change to NTSC are similar to what happens when an NTSC/PAL or PAL camera have been installed. John
GAP iiD BT-Sold
Post #428266 18th Feb 2017 5:21pm
miggit
Shocked Pal Shocked
Maybe it's a post 2009 thing.. and LR have upgraded the camera to pal Rolling Eyes
Anyway I suspect that they haven't improved the build quality so it's more than likely full of water sand sporting a broken PCB... if the car wants pal who are we to argue.. either way they can be had for as little as a tenner on the bay of fleas.. assuming that your up for a little modding Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #428267 18th Feb 2017 5:23pm
Andy B
Cheers Chaps, I think a replacement from Fleabay is on the cards. I'll have a closer look tomorrow for anything obviously not right Wink SDV8 AB MY 2019
Post #428270 18th Feb 2017 5:34pm
Andy B
No mate, it just decided to stop working....it is a Range Rover after all! Laughing SDV8 AB MY 2019
Post #428271 18th Feb 2017 5:35pm
Weegie
Very Happy
The new one needs to be NTSC. For some strange (read "daft") reason, when you try the 753 hack it goes, as you say, to PAL although a PAL camera doesn't work.
Must be the way the software was written. Possibly for a different use/vehicle. Confused John
GAP iiD BT-Sold
Post #428273 18th Feb 2017 5:41pm
miggit
Rolling Eyes I have lost the will to search, having waded through pages of Russian Microcat I now know that there was a change of camera at 6A216969.. but I suspect that was a mounting change.. and then you get to the 2010 section and the Censored 's have changed the part numbers completely Banging Head Banging Head
NTSC was the standard throughout the earlier cars so I think I'd possibly try one of those first.. You Are the Guinea Pig Shocked Laughing Laughing
Worst case you'll have to get a Pal camera too... but they there are a lot of owners on here with pre 2010 cars that might want a spare Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #428274 18th Feb 2017 5:43pm
Andy B
Cheers for trying to find out Thumbs Up Maybe I'll ask Ducky Dan and see if he can get his LR techy chums to clarify Rolling Eyes SDV8 AB MY 2019
Post #428283 18th Feb 2017 7:02pm
