![]() | Home > Technical (L322) > strange intermittent noise on motorway at 100kph ( 60MPH) - |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 ![]() ![]() ![]() |
I also get that noise at about the same speed, I've put it down to wind noise.
Roystonh Member Since: 21 Nov 2011 Location: Kent Posts: 395 ![]() ![]() |
I had that on my 2011 and it turned out to be the side vents being a bit loose. 2005 L322 Vogue Gold gone
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
check and clean the sunroof seals, they can get a bot crusty and cause a noise, my 12 did this when upto about 80 in france, quick check and clean and all was ok.
Cheers nmj, will have a look.
lounge_on_wheels Member Since: 10 Dec 2016 Location: in the great land of oz Posts: 269 ![]() ![]() ![]() |
Thanks will have a look at suggestions once this rain stops |
Nomad Member Since: 26 Oct 2011 Location: Ringwood, Hants Posts: 300 ![]() ![]() ![]() |
I had two similar noises at different times.
I had this on my L322 a few years back. I had stored one of those 1L bottles of oil and a rag behind the battery and that was causing it. Several good suggestions above. Try the simple stuff first, what you have is air not flowing as LR intended. |
Stuart Member Since: 06 Feb 2011 Location: Cambridge Posts: 85 ![]() ![]() ![]() |
Yes, I had a noise caused by a similar problem after having had a new windscreen fitted. The plastic strip down the sides of the windscreen was loose, and I could almost take it off (but couldn't see it bending back when I was driving, obviously). Autoglass came back and fitted new clips. |
muddycharles Member Since: 05 May 2011 Location: Miami, FL Posts: 90 ![]() ![]() ![]() |
Hi
Wow!!!! Thanks for the info. |
Fatzo Member Since: 11 Nov 2016 Location: Rigny Posts: 84 ![]() ![]() ![]() |
wow! I have it too when on motorway, especially when i put AC on
