Home > Technical (L322) > strange intermittent noise on motorway at 100kph ( 60MPH) -
lounge_on_wheels
Australia 2003 Range Rover HSE Td6 Zambezi Silver
I had an intermittent wind noise from the front of the vehicle 2003 L322 TD6, it is exactly like when you blow across the top of the neck opening on a glass bottle. It would come and go whilst I was on the motorway ( there was a slight cross wind blowing ) it was quiet loud and became annoying, it did this for a few kilometers then disappeared , What would cause this. Windscreen?
Post #428325 19th Feb 2017 6:50am
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
I also get that noise at about the same speed, I've put it down to wind noise.
mine seems to be coming from the n/side (passenger).
Haven't got a clue where its focused.
Post #428327 19th Feb 2017 8:03am
Roystonh
I had that on my 2011 and it turned out to be the side vents being a bit loose. 2005 L322 Vogue Gold gone
2006 L322 Vogue Black gone
2011 L322 Vogue Silver gone
2011 L322 Autobiography Black gone
2015 L405 Autobiography LWB Black gone
2019 L405 P400e Range Rover Autobiography LWB Eiger grey / black roof gone
2001 P38a 30th Anniversary Wimbledon Green gone
2019 L405 P525 Autobiography LWB British Racing Green
Post #428335 19th Feb 2017 11:20am
check and clean the sunroof seals, they can get a bot crusty and cause a noise, my 12 did this when upto about 80 in france, quick check and clean and all was ok.
could be that, but also check the edging round the windscreen and the bit where the roof rail strips meet the top of the screen and also check you have all 4 covers on the roof rack fix points as if you have one missing then this can cause some wind noise. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #428340 19th Feb 2017 11:45am
gregdav
Cheers nmj, will have a look.
Greg Thumbs Up
Post #428412 19th Feb 2017 7:39pm
lounge_on_wheels
Thanks will have a look at suggestions once this rain stops
Post #428473 20th Feb 2017 3:48am
Nomad
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Zermatt Silver
I had two similar noises at different times.
First was caused by something in the air vents. Strangely switching off the fan and switching back on cleared it. Might have been dried leaves or something.
Second was a missing clip for the black plastic A pillar cover. Apparently the new design clips are bigger than the old and fit better. Autoglass found it when fixing a chip and replaced the clip. No noise now. 2012 5.0L S/C
Previous:
3.6 TDV8
4.4 HSE
P38 4.6 HSE
Classic 3.9
90 County
Series3 Lightweight
Post #428476 20th Feb 2017 6:11am
mzplcg
I had this on my L322 a few years back. I had stored one of those 1L bottles of oil and a rag behind the battery and that was causing it. Several good suggestions above. Try the simple stuff first, what you have is air not flowing as LR intended.
Post #428509 20th Feb 2017 2:35pm
Stuart
United Kingdom 2011 Range Rover Vogue SE TDV8 Santorini Black
Yes, I had a noise caused by a similar problem after having had a new windscreen fitted. The plastic strip down the sides of the windscreen was loose, and I could almost take it off (but couldn't see it bending back when I was driving, obviously). Autoglass came back and fitted new clips.
Post #428514 20th Feb 2017 3:19pm
muddycharles
United States 2008 Range Rover HSE 4.4 V8 Bonatti Grey
Recirculation Flaps
Hi
This is usually due to the recirculation flaps. You can test it by turning the recirculation system off and on and you'll hear it. There is a a range rover kit specifically designed to address this, look up TSB number LTB00350NAS2
SECTION: 412
'Whistle' Noise from HVAC Recirculation Flap
AFFECTED VEHICLE RANGE:
Range Rover (LM) VIN: 5A181087 - Onwards Model Year: 2005 - Onwards
CONDITION SUMMARY:
Situation: A 'whistle' noise from behind the instrument panel when driving at speeds above 30mph (48kph) with the Heating Ventilation Air Conditioning (HVAC) in recirculation or Auto mode may be evident. This noise may be caused by air passing over the recirculation flap seals.
PARTS:
LR029201 ................Tape kit Qty: 1 2008 HSE B. Grey
Overfinched
NavTV retrofit
Post #428531 20th Feb 2017 5:32pm
gregdav
Wow!!!! Thanks for the info. Thumbs Up
Post #428607 21st Feb 2017 8:07am
Fatzo
France 2011 Range Rover Vogue TDV8 Ipanema Sand
wow! I have it too when on motorway, especially when i put AC on
Post #484191 23rd Jul 2018 10:28pm
