![]() | Home > Technical (L322) > 2 Post Lift |
MPx Member Since: 29 Jul 2011 Location: South Somerset Posts: 627 ![]() ![]() ![]() |
Sorry don't know the answer to your specific question - though I've never had a problem getting the trolley jack under the jacking points with fixed steps in place on an '07 and chrome tubes on an '02.
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
I had mine on a 2 post lift a couple of times without any worries, and I had factory sidesteps (running boards) If memory serves me right it had the longer spacers fitted to the pads and we had to put the car in high mode to clear them, apart from that no issues.... unlike trying to user a jacking beam on a 4 post lift... that was a mission!! Yesterday I couldn't spell Engineer... Today I are one!
What have you done to your Range Rover... they leave the factory at 2.6 tons.. unless it has blacked out windows and there's a bulge under your jacket... cos the only ones that I know that go over 2.6 ton are the armored.. about 4 tons.. but it's a secret, and I have to kill you...blar blar ![]() As for 2 post limits, unless it's very old you'll be hard pushed to find one under 3.5 ton rating, most are 4 ton. It's not the capacity of the lift that's the problem... it's the quality of the concrete that it's bolted to.. When I was training to be an Insane Mechanic , sorry ment Nissan, we were doing a PDI (pre delivery inspection) on a brand spanking new Patrol, on our shiny new 3.5 Ti Bradbury 2 post lift, lifted the car about 4 feet off the ground, BANG!!, the anchor bolts gave out on one of the posts, the dropped on one side and it got pinched under the post... RIP, damaged shell ![]() ![]() Inventor of the 'Guide-o-Matic automatic wheel alignment tool' Former long term L322 owner, Up/Down graded to a Classic Tractor! |
My bad then |
ipwn Member Since: 08 Aug 2015 Location: Yorkshire Posts: 50 ![]() ![]() ![]() |
Mine is a Nussbaum rated to 3 tonnes. Indeed the Kerb weight on the RR is 2.7..
It all rather depends on the lift arms and it the pads are adjustable or not, your gonna need about 4 inches of clearance Clarence to get around the steps |
