Home > Technical (L322) > TV in motion
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
TV in motion
Hi All,
Seen the hack or module upgrade to enable TV in motion but..... Can't you just pull the handbrake up one click whilst in D..? (it seems to enable it for me) Not sure if technically the handbrake (diff brake) is enaged to some degree though.?
Any thoughts.
Thanks Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #42884 20th Dec 2010 5:47pm
dan_uk_1984
Re: TV in motion
comports wrote:
Hi All,
Any thoughts.
Thanks
You can do that, but you will get a constant bonging warning you that the HB is up. Also what Diff Brake are you referring to? The handbrake works on the rear drums (inside the discs)
A better option is just to enable TV on the move in the software - easy and cheap.
Post #42899 20th Dec 2010 7:36pm
comports
Have they changed the design? I believe my p38 "hand brake" locks the centre diff not the wheels. Perhaps I was wrong all these years. !
Does that mean one could do handbrake turns in an L322?  Mr. Green Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #42901 20th Dec 2010 7:52pm
dan_uk_1984
The handbrake has never locked the Center Diff on any Land Rover/ Range Rover. On the P38 and Classic the HB used to operate a large Drum Brake on the output shaft to the rear off of the gearbox.
You could do HB turns in an L322 except it is 4wd so when the front wheels are turning the rear wheels are turning and likewise when the rear wheels are stationery the front wheels are stationery. This can be overcome by breaking your half shafts relatively easily though.
Black drum here:
Post #42912 20th Dec 2010 8:23pm
comports
Thanks for putting me straight Dan. Obvious I'm no mechanic but I try to keep up.... Most of the time..! Smile Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #42968 20th Dec 2010 11:02pm
daveo
you can do the tv in motion with software :navcoder:i have it, but to be fair do you have a digital or analog tuner V8 facelift Range Rover Autobiography 22" wheels.
Post #42975 20th Dec 2010 11:26pm
comports
I believe it's only the analogue version.... Something else to upgrade next year..! Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #42977 20th Dec 2010 11:28pm
dan_uk_1984
Any time Sheep
Post #42980 20th Dec 2010 11:35pm
Andy
I've got a brand new lead for sale that enables tv in motion. Bought two by mistake off eBay. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #42994 21st Dec 2010 7:06am
comports
Sent you a PM noddy.. Thx Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #43010 21st Dec 2010 9:49am
