![]() | Home > Technical (L322) > TV in motion |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1762 ![]() ![]() ![]() |
Hi All,
You can do that, but you will get a constant bonging warning you that the HB is up. Also what Diff Brake are you referring to? The handbrake works on the rear drums (inside the discs) A better option is just to enable TV on the move in the software - easy and cheap. ![]() |
Have they changed the design? I believe my p38 "hand brake" locks the centre diff not the wheels. Perhaps I was wrong all these years. !
The handbrake has never locked the Center Diff on any Land Rover/ Range Rover. On the P38 and Classic the HB used to operate a large Drum Brake on the output shaft to the rear off of the gearbox. You could do HB turns in an L322 except it is 4wd so when the front wheels are turning the rear wheels are turning and likewise when the rear wheels are stationery the front wheels are stationery. This can be overcome by breaking your half shafts relatively easily though. Black drum here: ![]() ![]() |
Thanks for putting me straight Dan. Obvious I'm no mechanic but I try to keep up.... Most of the time..! |
I believe it's only the analogue version.... Something else to upgrade next year..! Ash
Any time ![]() ![]() |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2947 ![]() ![]() ![]() |
I've got a brand new lead for sale that enables tv in motion. Bought two by mistake off eBay. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
Sent you a PM noddy.. Thx Ash
