Home > Technical (L322) > Best Tyre / size combination for Winter
What is the best wheel size and tyre combination for the sort of weather we seem to be getting each winter.
19' Wheels
15%
 15%  [2]
20" Wheels
0%
 0%  [0]
Snow and Mud Tyres
23%
 23%  [3]
'Winter' tyres
30%
 30%  [4]
'All Weather' tyres
7%
 7%  [1]
General AT2
23%
 23%  [3]
Continental
0%
 0%  [0]
Total Votes: 13
Page 2 of 3 <123>
bogie
I found when shopping for winter tyres, theres a load more choice at 19" or 18" than at 20" ...and cheaper too
the choice at 20" is getting better, but still limited to a couple of brands/models, which can be hard to get hold of cheers
bogie
Post #42762 19th Dec 2010 12:53pm
T24RES
Being slightly thick, can i run 19's over my brembo's? Thanks in advance. Ian
Post #42808 19th Dec 2010 8:47pm
Jem0911
United Kingdom 2015 Range Rover Vogue SE SDV8 Corris Grey
My AT's arrived Friday.
 15MY SDV8 Vogue SE
Post #42855 20th Dec 2010 1:31pm
Emperor Mong
United Kingdom 2019 Range Rover Autobiography 2.0 PHEV Loire Blue
are AT's rated as a winter tyre?
Post #42856 20th Dec 2010 1:39pm
Jem0911
Not through design, but they sell them on the website as good in snow.
As well as the off road ability.
 15MY SDV8 Vogue SE
Post #42857 20th Dec 2010 1:56pm
Fox
Yes
All terrains are good tyres for most things. Kind of an all-season with a bit more off road grip in my opinion.
Post #42860 20th Dec 2010 2:33pm
T24RES
Cheers foxy. I had GG AT2's on a previous car, very impressed off road n in snow. I'd go for the AT's on the 20's if only they made them . Ian
Post #42861 20th Dec 2010 2:45pm
I think Coopers do a very nice 20" AT tyre.....
Post #42875 20th Dec 2010 4:51pm
drakes
United Kingdom 2010 Range Rover Vogue TDV8 Stornoway Grey
Not being picky but I think you will find they are the new AT's not AT2's which are a completely different pattern.
I have the AT2's on a 90 and find them to be a better tyre than the Wintracs I have on the Range Rover in the current weather
Post #42881 20th Dec 2010 5:41pm
Jem0911
You sir are correct. 15MY SDV8 Vogue SE
Post #42888 20th Dec 2010 6:23pm
I still desire a set of these babies they look just so good on an L322:
Cooper LTZ Zeon
http://www.4x4tyres.com say its the best allrounder.....
http://www.tyrespec.co.uk/products/?pattern=Zeon%20LTZ
The truly awesome Zeon LTZ all-terrain tyre incorporates many state-of-the-art features including the following...
Sweeping Lateral Grooves and Irregularly Shaped Tread Elements:
These tread elements are used to provide solid all terrain performance. The optimized pitch sequence helps provide even treadwear and reduced tread related noise.
Transverse and Circumferential Grooves:
Which both play their part in directing water away from the tread pattern to resist aquaplaning.
Ridged Tie Bars:
Ridgid tie bars provide increased lug stability by locking the lugs while also creating an entrenched siping advantage within the channelled area for enhanced steering and traction.
Shoulder lugs:
Alternately scalloped and offset lugs give improved traction on soft surfaces like sand and mud.
CAD:
Using variable pitched sequence creates a balanced pitch to reduce noise while maintaining M+S traction capabilities and extended tread life.
Full Depth Siped Elements:
Full depth sipe elements provide for increased traction while reducing heat build-up within those elements for balanced wear.
Special Venting Technology:
Special venting is incorporated in the mould design of the tread area and provides a crisp, clean, premium appearance.
Rubber Rim Protector:
The rubber rim protector extends beyond the rim flange and reduces the chance of rim damage that can occur if a tyre or wheel assembly scuffs a kerb.
Also COOPER STT's look nice:
Last edited by Gazellio @ Prestige Cars on 20th Dec 2010 8:10pm. Edited 1 time in total
Post #42902 20th Dec 2010 7:53pm
bogie
can you get those Coopers in 20"? ...they seem to have a very limited range in larger sizes cheers
bogie
Post #42904 20th Dec 2010 8:04pm
Extreme Tyres:
(305/55-20 BFG KM2)
Last edited by Gazellio @ Prestige Cars on 20th Dec 2010 8:07pm. Edited 1 time in total
Post #42905 20th Dec 2010 8:05pm
Yes see the link i gave
They are very beautiful to behold (beats porn)
Post #42906 20th Dec 2010 8:06pm
And while we are on the subject of extreme tyres we must not leave out the:
Toyo M/T Open Country option:
Post #42910 20th Dec 2010 8:20pm
Page 2 of 3 <123>
