![]() | Home > Technical (L322) > Does crankcase filter cause turbo oil leak? |
lounge_on_wheels Member Since: 10 Dec 2016 Location: in the great land of oz Posts: 269 ![]() ![]() ![]() |
Merhubbah, When did you last replace the crank case breather filter, they should be replaced every service, most people forget them this could cause oil leaks. Replace with the new Vortex style so you don't ever have to preplace the filter again. |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7966 ![]() ![]() ![]() |
+1 for the above. The insert is enough.... did it on my TD6....
umitbat Member Since: 06 Jan 2010 Location: Space Posts: 433 ![]() ![]() ![]() |
Unnecessary quote removed
2 -3 services is too a long time I think. You can just remove the filter and its holder inside and just put the vortex part inside where the old filter was.
