Home > Technical (L322) > Does crankcase filter cause turbo oil leak?
umitbat
A Trap 2010 Range Rover HSE TDV8 Atacama Sand
Hi
There is sign of oil under turbo,but no oil decrease very tiny.
Can this be caused by crankcase filter,***??
Is changing the insert enough? 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #429671 2nd Mar 2017 5:37am
lounge_on_wheels
Australia 2003 Range Rover HSE Td6 Zambezi Silver
Merhubbah, When did you last replace the crank case breather filter, they should be replaced every service, most people forget them this could cause oil leaks. Replace with the new Vortex style so you don't ever have to preplace the filter again.
Post #429674 2nd Mar 2017 5:55am
mjdronfield
+1 for the above. The insert is enough.... did it on my TD6....
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #429677 2nd Mar 2017 6:37am
umitbat
Unnecessary quote removed
Merhaba;)
Vov so vortex is the end of problem!
They replace it 2-3 services a time as far as i know.
So is only the insert vortex or is it complete set? 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #429691 2nd Mar 2017 10:19am
lounge_on_wheels
2 -3 services is too a long time I think. You can just remove the filter and its holder inside and just put the vortex part inside where the old filter was.
like this
http://www.ebay.com.au/itm/RANGE-ROVER-L32...SwQTVWBUIl
i bought from this seller but was not happy with his service.
Post #429707 2nd Mar 2017 12:36pm
