Home > Technical (L322) > Another fault found on my L322. Fuel gauge faulty... |
S14WNO Member Since: 10 Mar 2017 Location: Lancs Posts: 24 |
13th Mar 2017 11:28am |
I just wannt to add... previous to replacing the cluster for pixel replacement everything was working as it should, its only since i have started unplugging and replacing the clusters that i have found the issues |
13th Mar 2017 11:30am |
any ideas anyone? i dont want to be using the range rover with the baby until i have sorted it out. I have had the dash off about 6 times playing with the previous cluster and replacing this one, i thought when i replaced the old one then my issues would be solved but its not the case. Could it be that it needs to be coded to my vehicle for it to perform correctly? or should the fuel gauge work regardless?... Was meant to pick my mrs up from work today but i didnt want to risk breaking down as i dont know exactly how much fuel is in there... |
13th Mar 2017 5:17pm |
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 819 |
Hi,
13th Mar 2017 5:29pm |
hello buddy, thank you for your reply. I have just done the text and they are all moving. It doesnt seem to be registering as it should. even when i fire up the car the speedometer is sat on the pin at the bottom of the cluster where on youtube videos i have seen it jumps up to 10k revs. The speedometer seems to be moving slower than the speedo on the test and the fuel gauge needle drops back down to hit the plastic on the side wall as shown in my pic above... not too sure what to do with it |
13th Mar 2017 5:39pm |
I hate to say it but you may have bought a dud.
13th Mar 2017 5:52pm |
i dont know anyone with a range rover im afraid, im just wondering if someone has done a pixel repair and not put the needles back how they should be. is there a way of moving them if i open up the cluster? i dont want to be pulling them out again after last time but if i can push them around somehow? I am way out of my depth here lol |
13th Mar 2017 6:04pm |
I think the only way is to remove the needles and you've not had much luck in that respect. If your worried about the amount of fuel left in your tank then I would be looking at the trip computer which gives the range left.
13th Mar 2017 6:32pm |
yes the original cluster was working fine before i started mauling with it, the cluster i have in now (replacement) is acting the same way as the old one was so i am wondering if someone has fluffed up the needles as i did with the original cluster.
13th Mar 2017 6:39pm |
I think i have figured it out... just done the test again with all the needles moving at the same time and the rev meter seems to be delayed and only goes so far and the fuel gauge needle only goes just above 3 quarters of a tank so i think these may need to be adjusted, thats if its possible. The other gauges are flying all the way and back... so fingers crossed i can adjust these tomorrow. I really wish i had a big garage with a nice big light in there |
13th Mar 2017 8:20pm |
Good luck my friend. I do all of my work on the drive too.... ______________________________
13th Mar 2017 8:46pm |
Thank you buddy, ill have a go tomorrow and let you know how i get on. Many thanks for your help |
13th Mar 2017 8:51pm |
The sod of it is I have a spare cluster, but it's for a 4.4 v8 petrol.. ______________________________
13th Mar 2017 10:04pm |
if it would of fitted i would of had it off you, i nearly bought the 4.4 cluster thinking it would fit ok lol |
13th Mar 2017 10:06pm |
