Home > Maintenance & Mods (L322) > Engine Cutting Out Intermittently - 2012 4.4 TDV8
Page 4 of 5 <12345>
It's good proof that diagnostic tools can help.
After seeing all the codes the one which stood out as the cause was the CPS fault, and the graphs of the signals proved it.
Glad it's sorted, for future reference can you give us a ballpark on the final cost Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #431653 19th Mar 2017 8:22pm
Baltic Blue
Excellent result.
Thanks for sharing this post; I am sure all 4.4 TdV8 readers have learned from you.
Cheers ! Very Happy G reg 2.5VM Vogue Portofino red 1991- 1999
Post #431654 19th Mar 2017 8:34pm
roel2018
Netherlands 2017 Range Rover Autobiography SDV8 Carpathian Grey
This could also solve my problem Cool 2017 Range Rover 4.4 SDV8 Autobiography DPF EURO6- 100k miles - Dutch
Post #547004 13th Mar 2020 3:14pm
bwelton
United Kingdom 2012 Range Rover Vogue SE TDV8 Zermatt Silver
I’ve had the best part of 5 years smooth running since replacing the Crankshaft Position Sensor.
Good luck. -------------------------------------
MY 2012 4.4 TDV8
Post #547017 13th Mar 2020 5:38pm
neil3728
United Kingdom 2013 Range Rover Vogue SDV8 Baltic Blue
Is it an easy fix, Mrs is complaining of a small loss of power for a second while driving today. 2013 Vogue 4.4 TDV8
2014 Defender 110. now sold
2018 Range Rover Sport.
Post #547019 13th Mar 2020 5:43pm
roel2018
In 3 weeks I have the MOT so I asked the LR workshop. Part number LR049872 is replaced by LR126062. They asked € 308 (or 270 pounds) for labour so I think it is a job for about 3 hours. They also check if my one has update LTB00454v2 is done. 2017 Range Rover 4.4 SDV8 Autobiography DPF EURO6- 100k miles - Dutch
Post #553454 11th May 2020 3:01pm
bwelton
I'm not sure about fitting. I had the garage fit it. -------------------------------------
MY 2012 4.4 TDV8
Post #553459 11th May 2020 3:26pm
roel2018
Today I was at the local LR workshop. My RR was not updated with LTB00454v2 so they run a diagnostic test. No failure was recognizable/logged, no failures for the crankshaft position sensor so that saves me a little €500 (446 pounds). The update cost me € 64 (57 pounds) so hopefully my problem is solved...
To be specific:
They re-programmed the PCM (Powertrain Control Module, part LR023239) with the newest software (LTB00454V2).
Technical bulletin LTB00454v2 says it will solve the problem when driving between 60 mph and 90 mph, with an ambient temperature above 10 degrees and in 6th, 7th or 8th gear. 2017 Range Rover 4.4 SDV8 Autobiography DPF EURO6- 100k miles - Dutch
Post #554524 19th May 2020 9:52pm
GraemeS
Australia
Can anyone advise the suggested time to update the PCM as presumably shown on LTB00454 please? My L322 is booked to have the update done tomorrow morning and I'd like to have some idea of the time. It is also booked to have the BCM updated and as there are several other modules that aren't at the latest level I'll be trying to get them all updated, but I expect the PCM to take the longest by a fair margin.
TIA.
Edit: I can't decipher Chinese but suspect the 0.2 in the box on page 1 is the time, which will be great if correct.
Post #558820 24th Jun 2020 11:10am
neil3728
Does the update have to be done at a Land Rover garage, Mine us rather useless recently.
Also does anyone have any idea what the update would costs. I only bought my car in Feb so not sure how upto date anything is. 2013 Vogue 4.4 TDV8
Post #558823 24th Jun 2020 11:20am
GraemeS
Australia
Gap has advised that their tool can't do the update.
I was advised that my local dealer's labour rate is $176 per hour so I'm hoping for not more than half an hour total.
Post #558825 24th Jun 2020 11:22am
jackie-o
Netherlands
Slightly off topic but I am getting the software update for the gearbox done next week as above (LTB00454v2)
Are there any other software updates that are important/should be done while they are at it? RR Vogue 4.4 TDV8 - 11
Toyota Land Cruiser Prado - 02
LR Discovery 4 SDV6 -11 - Gone
RR Vogue 3.6 TDV8 - Gone
Post #559898 2nd Jul 2020 11:00am
roel2018
Ok. Last year my fattie was updated with LTB00454v2 in March 2020. But yesterday it happens again twice! So, i think i need a new CPS Crank Positioning Sensor.... 2017 Range Rover 4.4 SDV8 Autobiography DPF EURO6- 100k miles - Dutch
Post #598243 21st Jun 2021 11:08am
GraemeS
Australia
The sensor has been superseded twice since our vehicles were built so maybe improved.
Post #598246 21st Jun 2021 11:42am
roel2018
Which one is the latest for the TDV8 4.4 diesel? LR126062? Or the LR049872? 2017 Range Rover 4.4 SDV8 Autobiography DPF EURO6- 100k miles - Dutch
Post #598251 21st Jun 2021 12:22pm
Page 4 of 5 <12345>
