![]() | Home > Technical (L322) > L322 flat battery |
| Realist Member Since: 13 Feb 2016 Location: Wales Posts: 436
See below pic for where the cable was going to.
| miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3669
It's very hard to make out from the Microcat diagram as they have included every lead known to man.. if it doesn't go to the starter then I would, in light of the faults you've encountered, surmise that it must go to the alternator..
| UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 836
I think it's this cable (item 5) part no. LR012377 and it does go to the starter motor -
Nope the blast pack is there as is the cable going to the starter, this cable is going somewhere else. Range Rover quotes.....
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8788
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434
Is it a cable to the glowplugs?
Now that's more like it still strange why a flat fuse? Range Rover quotes.....
I think we need photographic evidence from someone with the same model - I'm not getting any sleep because of this |
Ok round 33 and a 3rd........
Ah right, the lead on the bottom is there. The other lead is still a mystery as there wasn't one there on my 3.6, see earlier pic, so possibly a winch connection as said, can think what else would need a lead that big, the rest of the cars electrics are on the other 2 leads. There is nothing that can't be fixed with a hammer😜😜
Yes so I'm looking for an alternator now.
It's a denso unit, can be had from either ECP or carparts4less (same as ecp but were cheaper) there are 2 types available depending on the pulley type and how many ribs are on your drive belt.
Thanks, will dig the vin out and ask Dan.
Range Rover quotes..... The Luxury That�s More Than a Luxury. Conquer the world, and look good doing it. Built for the unexpected. Over prepared, but never underdressed. 2007 Vogue SE TDV8 Epsom Green (old car). 2010 Discovery 3.0L GS Mk4 Black. |
Your cable looks very much like an after thought add on... for a kick off if it was a factory lead it would be red.. not black.. so either you've got the mother of all stereo's lurking in the boot, or I think that it would either be a winch power cable or jump start cable, I can't think of any other add on item that would require such a heavy lead...you haven't got a couple of megawatt spot lamps fitted have you? |
| All times are GMT |
