Home > Technical (L322) > L322 flat battery
Page 3 of 4 <1234>
Realist
Wales
See below pic for where the cable was going to.
 Range Rover quotes.....
The Luxury That�s More Than a Luxury.
Conquer the world, and look good doing it.
Built for the unexpected.
Over prepared, but never underdressed.
2007 Vogue SE TDV8 Epsom Green (old car).
2010 Discovery 3.0L GS Mk4 Black.
Post #433355 31st Mar 2017 5:32pm
as a property job i would get it attached back to the bottom of the explosive pack, which may or may not be Duff..... There is nothing that can't be fixed with a hammer😜😜
Post #433358 31st Mar 2017 5:45pm
miggit
It's very hard to make out from the Microcat diagram as they have included every lead known to man.. if it doesn't go to the starter then I would, in light of the faults you've encountered, surmise that it must go to the alternator..
I no longer have an L322 to trace the wire, but you do Wink On my Range Rover the big wire goes to the winch and the other battery Very Happy .... I'm not helping very much am I? Mr. Green Yesterday I couldn't spell Engineer... Today I are one!
Post #433396 31st Mar 2017 9:34pm
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
I think it's this cable (item 5) part no. LR012377 and it does go to the starter motor -
I may be wrong as miggit says there are loads to choose from Thumbs Up ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #433423 1st Apr 2017 7:34am
Realist
Wales
Nope the blast pack is there as is the cable going to the starter, this cable is going somewhere else. Range Rover quotes.....
Post #433438 1st Apr 2017 10:44am
this will help, cable goes to starter and alternator! There is nothing that can't be fixed with a hammer😜😜
Post #433441 1st Apr 2017 11:07am
Is it a cable to the glowplugs?
Found this diagram in the 2007-2010 Workshop manual which shows the "flat fuses": 2
3 is the ignition switch and 6 is the ECM
Post #433443 1st Apr 2017 11:28am
Realist
Wales
Now that's more like it still strange why a flat fuse? Range Rover quotes.....
Post #433445 1st Apr 2017 11:57am
UK Marine
I think we need photographic evidence from someone with the same model - I'm not getting any sleep because of this Very Happy ______________________________
Simon
Post #433453 1st Apr 2017 1:42pm
Realist
Wales
Ok round 33 and a 3rd........
I purchased a battery and alternator tester and its saying the new battery is low in charge and the max voltage is 12.4v and the alternator is Censored .
Put the tester on the old battery and the tester says its ok but low so swopped battery's car starts and the readings are the same.
So now I'm more leaning towards the alternator Sad
Here is a pic of the live terminal showing the blast pack and the 2nd red lead.
So I'm more inclined to say the 2nd lead is going to something else but where? Range Rover quotes.....
Post #433463 1st Apr 2017 3:04pm
Ah right, the lead on the bottom is there. The other lead is still a mystery as there wasn't one there on my 3.6, see earlier pic, so possibly a winch connection as said, can think what else would need a lead that big, the rest of the cars electrics are on the other 2 leads. There is nothing that can't be fixed with a hammer😜😜
Post #433464 1st Apr 2017 3:10pm
Realist
Wales
Yes so I'm looking for an alternator now.
Anyone know of the type number? Range Rover quotes.....
Post #433468 1st Apr 2017 3:16pm
It's a denso unit, can be had from either ECP or carparts4less (same as ecp but were cheaper) there are 2 types available depending on the pulley type and how many ribs are on your drive belt.
Microcat has it at LR026344
Looked on Lrdirect as well and it is £204 for the Denso unit.
Would double check with Dan via your vin that this is the right part number tho. There is nothing that can't be fixed with a hammer😜😜
Post #433471 1st Apr 2017 3:24pm
Realist
Wales
Thanks, will dig the vin out and ask Dan.
Thanks again.
Post #433479 1st Apr 2017 4:02pm
miggit
Your cable looks very much like an after thought add on... for a kick off if it was a factory lead it would be red.. not black.. so either you've got the mother of all stereo's lurking in the boot, or I think that it would either be a winch power cable or jump start cable, I can't think of any other add on item that would require such a heavy lead...you haven't got a couple of megawatt spot lamps fitted have you? Rolling Eyes
It could be a large inverter... got and 13 / 16 amp sockets floating around? Yesterday I couldn't spell Engineer... Today I are one!
Post #433570 2nd Apr 2017 1:23pm
Page 3 of 4 <1234>
