Home > Technical (L322) > Urgent help needed * SOLVED *
Andy
I've just managed to lock my only key in the boot. I unlocked the boot and put the keys in there whilst unloading. Then slammed it shut without thinking. That's what happens when you finish a night shift!
Can someone PM me a way to get in please before I call out the AA
Thanks
Post #433542 2nd Apr 2017 10:27am
steveball
United Kingdom 2010 Range Rover Vogue SE TDV8 Bournville
You don't want to hear this, but your car is very secure. I did the same and called the breakdown service. They sent a lock specialist, with various tools including an inflatable bag to bend the top of the door frame open enough to get a rod in to hook the door handle or press the unlock button. It didn't work though because, by default, its deadlocked so the interior handles and button don't work.
In the end, the breakdown guy took my wife about 25 miles home to fetch the spare key.
I suggest you call the AA and see what they can do. If you only have one key, I think you will need to get it. If it's possible to hook the key somehow, it may be possible to do so without breaking a window. If not, prepare to clear up some glass. Current: 2010 Range Rover L322
Vogue SE, TDV8 3.6, Bournville
Now gone: 2002 Range Rover L322
Vogue, TD6, Giverney Green
Post #433557 2nd Apr 2017 12:01pm
mr_spock
Can you get a long flat thing, like a very long steel rule, through the door seal and press the lock button?
Post #433559 2nd Apr 2017 12:16pm
daz62
United Kingdom 2003 Range Rover Vogue SE 4.4 V8 Oslo Blue
You have a PM Andy 03 4.4 V8 petrol / lpg. 1st of many hopefully. I love my Rangie
Post #433564 2nd Apr 2017 1:03pm
the RAC can get in but it involved bending the window out slightly Big Cry , and apparently there is a way, however its never been posted on here so no idea I'm afraid.
some say removing the number plate lights and handle button gives access to the lock. it doesn't. I've just taken mine off to see. and theres nothing there just a cavity, which on mine is handily filled with dinitrol!
its a pitfall. that moment you shut the boot and realise the keys are in it and you used the little boot opening button to release it. There is nothing that can't be fixed with a hammer😜😜
Post #433565 2nd Apr 2017 1:04pm
Baltic Blue
Try ringing LR Assistance. 0800 521786.
Even if you are not covered they may offer telephone advice? G reg 2.5VM Vogue Portofino red 1991- 1999
Post #433567 2nd Apr 2017 1:51pm
Andy
I sorted it. Keys retrieved and no damage!
Post #433610 2nd Apr 2017 9:08pm
