Home > Maintenance & Mods (L322) > brembo caliper leaking
Andy_J
Scotland 2007 Range Rover Vogue SE TDV8 Java Black
Just replaced all the brake line on my FF. Thought I had it all sorted with no leaks, but noticed on my way home from work the brake pedal would slowly drop to the floor. I can see brake fluid on the front passenger wheel.
Noticed when I was bleeding the brakes the front passenger inner bleed nipple was really stiff and had to work it a bit with release oil to get it moving. Felt I had to do it up a bit tighter than I would have liked at the time.
I know I can tighten it up a bit more, but I am now worried the tread is stripped due to it being an alloy calliper.
Choices are
1. Tighten it an hope I can stop the leak without stripping the thread.
2. remove bleed nipple and check for something stopping the nipple sealing, but it is really tight and thread may be knackered
What do we think is best 56 TDV8 Vogue SE
9 Freelanders, 2x 2002 TD4ES, 2001 TD4, 2002 1.8GS, 2000 XEDI, 2x 2000 1.8ES, 2004 1.8 & 2000 1.8 GS (rolled)
91 Lotus Carlton (sold)
90 Lotus Elan (BRG)
Post #433759 3rd Apr 2017 9:57pm
speedymarktd6
United Kingdom 2010 Range Rover Vogue SE TDV8 Santorini Black
Could you put a new nipple on , atleast you'll know that bit is good and then go from there onto no6 Range Rover
Everyone needs a hobby
Post #433785 4th Apr 2017 8:26am
nino_nino
I use teflon tape on mine, prevents leaks and is easier to loosen later.
Post #433820 4th Apr 2017 3:50pm
Andy_J
one of my concerns at the moment is will the tread strip when I try to take the bleed nipple out. so new bleed nipple may not be an option
Fluid is coming from centre of the nipple and not round the sides. Not keen on Teflon tape on brakes anyway 56 TDV8 Vogue SE
90 Lotus Elan (BRG)
Post #433838 4th Apr 2017 6:32pm
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Unfortunately right now you only have the one option. Just tighten it very softly and slowly while someone is depressing the brake pedal and use a spanner not a socket.....
Sorry can't be of any more help... ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #433844 4th Apr 2017 7:10pm
Andy_J
You are probably correct 'UK Marine' I am hoping someone comes up with a magic solution as I know if I strip the threads I will probably end up with more problems as the calliper bolts will probably strip as well 56 TDV8 Vogue SE
90 Lotus Elan (BRG)
Post #433869 4th Apr 2017 10:06pm
Andy_J
In case anyone has a similar issue in the future. I removed the leaking bleed nipple today and there was plenty aluminium welded to the treads and the bore was stripped smooth of treads.
Calliper came off easily so I am going to drop it into a local machine shop to see if they can fix it with either an oversize thread bleed nipple or something. 56 TDV8 Vogue SE
90 Lotus Elan (BRG)
Post #434399 9th Apr 2017 9:42pm
