![]() | Home > Maintenance & Mods (L322) > brembo caliper leaking |
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 ![]() ![]() ![]() |
Just replaced all the brake line on my FF. Thought I had it all sorted with no leaks, but noticed on my way home from work the brake pedal would slowly drop to the floor. I can see brake fluid on the front passenger wheel.
speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727 ![]() ![]() ![]() |
Could you put a new nipple on , atleast you'll know that bit is good and then go from there onto no6 Range Rover
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
I use teflon tape on mine, prevents leaks and is easier to loosen later. |
one of my concerns at the moment is will the tread strip when I try to take the bleed nipple out. so new bleed nipple may not be an option
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 835 ![]() ![]() ![]() |
Unfortunately right now you only have the one option. Just tighten it very softly and slowly while someone is depressing the brake pedal and use a spanner not a socket.....
You are probably correct 'UK Marine' I am hoping someone comes up with a magic solution as I know if I strip the threads I will probably end up with more problems as the calliper bolts will probably strip as well 56 TDV8 Vogue SE
In case anyone has a similar issue in the future. I removed the leaking bleed nipple today and there was plenty aluminium welded to the treads and the bore was stripped smooth of treads.
