Home > Technical (L322) > TDV8 no power, white/blue smoke
Page 3 of 5 <12345>
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
It was a quantum agent in Lucan , Dublin He looks after the car for me and the remap gives the car a nice extra surge that's really noticeable on each gear change 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #405838 22nd Sep 2016 12:37am
berkshirelad
United Kingdom 2007 Range Rover Vogue SE TDV8 Tonga Green
alanm_3 wrote:
So, assuming the MOT tester probably won't even open the bonnet, it's a bit of a moot point then? Whistle
MoT tester has to open the bonnet, both to test it's latching security and that the battery is secured
Post #405860 22nd Sep 2016 8:16am
SteveMFr
Site Sponsor
BAS can do a remap with the egr's disabled. And you can use the IIDTool to flash the remap Whistle
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #406222 24th Sep 2016 8:53pm
rar110
BAS remap with mapping out the EGR is another good solution. It just didn't suit me at the time. ______________________________
Post #406244 25th Sep 2016 12:56am
LASBAM
Germany 2007 Range Rover Vogue TDV8 Orkney Grey
TDV8 no power / white smoke
Hello together from Germany,
i have a very bad problem with my '07 TDV8 and hope someone can help me.
283000km - i was on the Autobahn and suddenly i had a loss of power (60% loss). Shocked Shocked
The car didn't went faster than 100km/h. No smoke, no trouble code in instrument, no wrong noises.
I went to the side of the road but there was non problem expect from the power loss so i decided to drive slowly home.
After 10 km i recognized the car starts to smoke white, so i let it bring to LR by flatbed.
The Landy Dealer first said both Turbos are smoken after he put a tester on it and there was a trouble code, but there was no black/white smoke while i drove. Nevertheless the TDV8 had a lack of oil when they looked.
Today i received a phone call in which he told me the engine would have a fatal damage because it runs not smooth. Big Cry Big Cry Big Cry Big Cry Big Cry Big Cry
Does someone has an idea what could be a alternative problem, because i can hardly believe both turbos have gone up...??
Post #433855 4th Apr 2017 7:20pm
rar110
If there's no oil on the dipstick then turbo failure is likely. The next question is how bad is the motor and what else needs replacing eg intercooler and EGRs. If the motor runs you might be lucky and only have to replace the turbos. However I would be getting the EGRs mapped out, disabled with emulators or new EGRs fitted. You don't want to fit new turbos only to have the EGRs break apart and bits fall into the motor. ______________________________
Post #433865 4th Apr 2017 8:39pm
LASBAM
Correct, there was only a few millimeters to minimum on the dipstick. The engine runs smooth when running with no load but the car smokes from the left exhaust fume like a steam train..
To map out the EGR is a difficult thing in Germany due our "TÜV-AU" exhaust regulations are very strict and if you map them out it's detected via OBD and then you lose the permissibilty of the car -->new EGR.
Is there any trick i can check with a tester or else wether it's only the turbo. Maybe some compression test ,etc..?
Post #433867 4th Apr 2017 9:04pm
rar110
That's good news. Best way is to check the output hose from the turbo to the intercooler. If it's got lots of oil in it the turbo seal has failed.
EGR emulators and be fitted and removed in minutes.
You could remove and check the top intercooler hoses for a split. You really have to remove them to check properly. I'd start there as it's easier. ______________________________
Post #433879 4th Apr 2017 11:11pm
LASBAM
Unfortunately Land Rover did already check the hoses for little splits as they said they do it every time with no result.
The guy from the LR service told me there need be a trouble code in the instrument cluster if it was only the EGR..
How much hours do you think will be needed for a single turbo replacement ?
Is it definitely necessary to put off the body or can it also be done without ?
Post #433906 5th Apr 2017 11:18am
dolph34
Had my done recently and its an engine out job , took my mechanic about 8 hours in total and we reconditioned both turbos while we were at it and we changed the turbo hoses for the silicone ones because they would be impossible to do normally. 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #433933 5th Apr 2017 3:44pm
LASBAM
Hello together,
today i received a nice bill from my landypoint and also the fault codes report.
Maybe someone can tell me some more Twisted Evil
P065E-00
P023D-22
P010C-21
P010F- 62
P0101-16
P00B8-21
P02AC-00
Together with a LR mechanics i started the RR, it runs smooth but there was coming a little blue "fart" out of the engine departement and additionaly there came very little blue smoke out of the left exhaust fume. Please excuse my bad English, but it has been a while ago since i wrote English...
Post #433953 5th Apr 2017 6:30pm
rar110
Gday
Try searching on here, or googling, each code. I'm sure something will come up. ______________________________
Post #433969 5th Apr 2017 8:24pm
LASBAM
TURBO Replacement - any ideas where to source?
hello together,
i will have to change at least one of my turbos.
Any suggests for me wether a new turbo or bespoken ?
Or is it rewarding to send them for a service?
best regards
Post #434601 11th Apr 2017 1:06pm
dolph34
Just my opinion but recon turbos are the same as new if bought from a reputable source and get the two turbos done at the same time 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #434634 11th Apr 2017 5:28pm
LASBAM
Hello together,
yesterday i started up the tank after cleaning the air intake, MAF, MAP Sensors. Car runs smooth but burns oil..
Right Side of the intercooler had a bit of oil in it.
Hope the youtube video link works to show you the smoke..
Whats your opinion on the turbo? Could it also be a defect oil separator?
Post #435602 22nd Apr 2017 9:21am
Page 3 of 5 <12345>
