Home > Maintenance & Mods (L322) > Which side vents should I have?
randomusername
Hi
Just been poking round my new (to me) RR, and it looks like it's got the wrong side vents fitted for the year...
It's a 2010 facelift, and has the honeycomb style front grill, however the side vents are the 3 vent style as fitted to the earlier cars. Should it have the mesh / 3 bar ones instead?
The side vents, front grill surround and bonnet inset panel and door handles are all colour coded the same dark grey so if it has been changed to the earlier style someone has taken their time doing it...
Cheers
Jon
Post #434361 9th Apr 2017 5:57pm
Spooky
United Kingdom 2014 Range Rover Autobiography 5.0 SC V8 Corris Grey
Very early versions were like this (mine's another example) - I prefer the later type, but trying to get a pair at reasonable prices is driving me bonkers!
 Regards,
Mick
'Bertha' - 2014 SDV8 Autobigraphy
'Vincent' - 2010 TdV8 Vogue SE
- 'Molly' - 2005 HSE Auto
'Dixie' - 2000 D2 Td5 ES
Post #434362 9th Apr 2017 6:12pm
mjdronfield
Bright finish power vents were an option. Standard ones are top left, like mine....
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #434363 9th Apr 2017 6:14pm
randomusername
Guess mine must be an early facelift then - the vents are exactly the same as Spooky's...
The reason I was poking round is because the lower plastic scuttle panel beneath one of the vents doesn't line up perfectly with the door line Sad Still need to try and figure that one out!
Post #434365 9th Apr 2017 6:29pm
mjdronfield
My pic was from the 2010 brochure, so it looks like good old Land Rover didn't do what they said.... suppose you can see if you can get the 3 bar ones to fit better, or change to the mesh ones...... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #434368 9th Apr 2017 6:43pm
randomusername
At some point I'll take the vents off and have a proper look. It's one of the many little jobs on the list!
Post #434370 9th Apr 2017 6:48pm
