![]() | Home > Technical (L322) > 2nd and possibly the more complicated - smoke |
Clivefog Member Since: 23 Aug 2015 Location: Bristol Posts: 354 ![]() ![]() ![]() |
Smell it is it acrid?
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 ![]() ![]() ![]() |
I would have said Webasto purely on your description Current: TDV8 (3.6) RRS HSE
Busa1400 Member Since: 05 Oct 2015 Location: Leeds Posts: 112 ![]() ![]() ![]() |
Thanks for the replies.
Don't know why or if it is the heater, when it is dark open the bonnet and have a good torch ready start it up and shine the torch in the suspect area to confirm where it is coming from. |
The Webasto comes on to help heat your car up quicker. Larger Diesel engines take an eternity to heat up and produce hot air. When you use the remote key fob or timed climate on the display you are just heating things up without your engine running. Current: TDV8 (3.6) RRS HSE
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
Is the engine hot or cold when you see the "wisps" ? |
The car is cold, it is just after very short runs.
do you hear webasto fuel pump clicking sound, that will tell you if heater is working. |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1408 ![]() ![]() ![]() |
My guess is that it is fumes from your fuel burning heater, they exit from the driver side wheel arch on mine, but depending on wind direction the fumes could be blown somewhere else. The heater is designed to come on when it is below 5 degrees, it happens automatically. If you have just done a short journey it runs on a bit after you have stopped the car and then you see the fumes. I had exactly that just now when I had driven the car to the shops and back to dry the brakes off after washing it, perfectly normal and nothing to worry about, though it is not pleasant to be in the garage when the heater is burning off (or healthy). Only Range Rovers since 1988 |
Thankyou very much, it all now makes sense.
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 830 ![]() ![]() |
When used for pre heat, the Webasto will come on at below 15 degrees.
