Home > Technical (L322) > 2nd and possibly the more complicated - smoke
Busa1400
England 2007 Range Rover Vogue SE TDV8 Santorini Black
I have had a good look around the site and cant seem to get to the bottom of where I'm at.
4.4 MY 2012 TDV8
I am getting what looks like exhaust smoke drifting over the front drivers side light occasionally. I say exhaust smoke because it is not black smoke or white etc. I am only getting wisps but it is there.
i do have a pre heater, that is working fine but has not been used for a couple of weeks.
I was sitting in the car this morning engine running waiting for wife, the car had been run and was up to temperature, when I got out to grab something off her, I could see the smoke round the front offside wing.
It seems according to the threads on here
1. diesel from a split o ring on diesel rail
2. Pre heater issue.
Any other ideas that I could look into ?
Thanks in advance. 2011 Range Rover Vogue SE
Post #435083 16th Apr 2017 4:38pm
Clivefog
Smell it is it acrid?
Feel it is it greasy or watery?
Post #435089 16th Apr 2017 6:04pm
stu
I would have said Webasto purely on your description Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #435099 16th Apr 2017 6:56pm
Busa1400
Thanks for the replies.
Looking under the bonnet nothing immediately obvious, and can't smell anything - as I say it is a wisp going by the headlight
Why would the webasto be on ?. I have not pressed the heater etc ? 2011 Range Rover Vogue SE
Post #435105 16th Apr 2017 7:46pm
Clivefog
Don't know why or if it is the heater, when it is dark open the bonnet and have a good torch ready start it up and shine the torch in the suspect area to confirm where it is coming from.
Post #435109 16th Apr 2017 8:11pm
stu
The Webasto comes on to help heat your car up quicker. Larger Diesel engines take an eternity to heat up and produce hot air. When you use the remote key fob or timed climate on the display you are just heating things up without your engine running. Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #435117 16th Apr 2017 8:54pm
nino_nino
Is the engine hot or cold when you see the "wisps" ?
Post #435158 17th Apr 2017 11:12am
Busa1400
The car is cold, it is just after very short runs.
So working on the basis that the Webasto is firing up to help heat the engine - why would I only just be noticing the smoke now ? 2011 Range Rover Vogue SE
Post #435213 17th Apr 2017 6:04pm
nino_nino
do you hear webasto fuel pump clicking sound, that will tell you if heater is working.
Post #435223 17th Apr 2017 7:02pm
CS
My guess is that it is fumes from your fuel burning heater, they exit from the driver side wheel arch on mine, but depending on wind direction the fumes could be blown somewhere else. The heater is designed to come on when it is below 5 degrees, it happens automatically. If you have just done a short journey it runs on a bit after you have stopped the car and then you see the fumes. I had exactly that just now when I had driven the car to the shops and back to dry the brakes off after washing it, perfectly normal and nothing to worry about, though it is not pleasant to be in the garage when the heater is burning off (or healthy). Only Range Rovers since 1988
Post #435228 17th Apr 2017 8:00pm
Busa1400
Thankyou very much, it all now makes sense.
I haven't noticed it before as I brought the car in the summer, i.e. above 5 degrees
It has not been a particularly cold winter so I only noticed it now and again.
excellent.
Thanksyou 2011 Range Rover Vogue SE
Post #435237 17th Apr 2017 8:23pm
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
When used for pre heat, the Webasto will come on at below 15 degrees.
I always thought my webasto was on the near side of the car, not the drivers side / offside.
I do occasionally see puffs of smoke from the left / near side front wheel arch area.
With the engine running the pre heat will turn off.
I don't know at what temperature the webasto operates as an auxiliary heater.
Post #435255 17th Apr 2017 10:33pm
