![]() | Home > My Range Rover > My Remapped 2002 Range Rover Vogue 4.4 V8 |
phat_dogg Member Since: 28 Mar 2017 Location: Sydney Posts: 8 ![]() ![]() ![]() |
The black looks good |
green-oval-nut Member Since: 02 Sep 2016 Location: Tunbridge Wells, Kent Posts: 930 ![]() ![]() ![]() |
Thank you. |
I forgot to post a picture as to why I need a third brake light and panel.
Today turned out quite good for the L322, I finally managed to get the light guards fitted. I need to buy slightly longer bolts for securing the lights though as the original bolts barely catch, but the lights are secure.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
Good work!!
Yeah, I thought about the front light guards, but for the look I am going for on the front, I decided against adding them. Cheers for the heads up though.
Somehow today, I found myself with about half an hour to kill between meetings, and on route to the next meeting I realised I was passing by a BMW specialist I used to use for my 728 BMW, and got an estimate for the chain. 14 hours at £48 per hour labour plus approximately £300 in parts. So looking at an estimate of £1032.
b348xyx Member Since: 29 Sep 2016 Location: Kent Posts: 319 ![]() ![]() ![]() |
If your getting the timing chain replaced, there lots of bits worth doing at the same time. For that price i would think they would be missing bits which should get done. And make sure the timing chain guides are OEM. 2003 Range Rover 4.4 Litre V8 - Adriatic blue
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3241 ![]() ![]() ![]() |
Cost me £3,000 (labour £75 per hr)
Thanks dolphinboy. I will look into it. |
L322 is home after being away for 24 hours to have the rear brakes sorted. Since the MOT and parking the car pointing downwards on a slight hill, I noticed I was getting the standard oil puddle on the floor, only a tiny one. So asked the garage to look into it. I was not happy when I was told one of the things that is leaking is my rocker gaskets, considering the garage supplied and fitted them back in September 2016 and the car has barely even covered 1500 miles since I have owned it |
Without any planning, my restful Sunday ended with me buying a job lot of parts for my car which worked out cheaper than buying some of the parts I needed out of this lot individually. I spent a little too much though including using the MOT money for both the P38 and Zafira lol. So now need to recoup some of the money asap. 1 part I found very interesting is the spoiler that has been attached to the front bumper. If the bumper was the right colour, I would be tempted to try it on my car just to see how it looks lol. But it is silver and I am not interested in adding it to my car.
Some people say I have had nothing but bad luck for the last couple of years, but now I feel that I am having some good luck despite the new neighbours not being nice people. I got superb news from the hospital in London today about life changing surgery I have been jumping through hoops for, for over 2 years, I met a great Range Rover owner today who I did a grill swap with for my P38 which helped him with the restoration of his P38 and me with the modifications on mine. I have bought a complete front end for my L322, so now have lights I can modify that don't have broken brackets. The stuff out of my outbuildings is selling pretty quickly so project money is coming in, and a couple of other positive things that I can't mention just yet.
I could really cry sometimes, coolant loss issue again. No visible signs of where it is coming out, No signs of it mixing with anything, I am hoping that it may have been 1 final air lock from somewhere, but suspect that the coolant may be going into the gearbox. I hope not, but I will be parking this Range Rover up within the next month hopefully while I use my other one if I can get the other Range Rover sorted within the next couple of weeks. |
