|  | Home > Technical (L322) > Stop Engine Low Oil Pressure at start up from cold |
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8002      | Not an expert, but I'd make sure the sensor wasn't faulty first.... easy fixes first and all that. 2011 Range Rover Vogue SE 4.4 TDV8
|  23rd Apr 2017 12:36pm |
| simon70 Member Since: 04 Apr 2017 Location: Shropshire Posts: 9      | I intend to replace the sensor and have the filter checked. I've just been out to have a look, the oil leak has gone which is a relief. The garage had a bit of a mare doing it, the o/s gave the trouble took him 3 attempts to do it. What bemuses me is it's been with him on the ramp since Wednesday, he started it on Friday and dropped it round to me. I asked him does it need to come back for anything, he said no. If I'm getting the flickering can and the bong surely he did to! I've just started her up, rattly initially and then settles down. The oil can came on and the bong then went away. My man suggested I google Wynn's or an equivalent additive to help free up the hydraulic Tappets. Ths may or may not be right move going forward, Im hoping someone on the forum may be able to advise | ||
|  23rd Apr 2017 1:03pm |
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8002      | Has it got a genuine Land Rover oil filter? I understand some have some sort of bypass valve in which if it doesn't work right can cause issues? Ive never had one of these engines, just thinking of the easy stuff. 2011 Range Rover Vogue SE 4.4 TDV8
|  23rd Apr 2017 1:32pm |
| simon70 Member Since: 04 Apr 2017 Location: Shropshire Posts: 9      | As yet I don't know, Im not really a spanner man. I've bought an oil pressure switch of eBay, and was thinking of a K&N Filter but am open to suggestions. I've owned it about a month now, I don't use it every day but will in the winter months. It's had an oil and filter change in March allegedly, but the same eBay wide boy also told me the gaskets had been done! Simon Goodwin | ||
|  23rd Apr 2017 2:14pm |
| b348xyx Member Since: 29 Sep 2016 Location: Kent Posts: 319      | the rocker cover gaskets may have been done just incorrectly, there a correct way to do it and wrong way..
|  23rd Apr 2017 2:56pm |
| simon70 Member Since: 04 Apr 2017 Location: Shropshire Posts: 9      | My mechanic told me he would need it for two days to do property, and I know it was something he had a struggle with in particular the o/s. I've got a good relationship with him so between us we will sort it out. I'm happy with my Range Rover, for what it cost I'm expecting a few things to sort Simon Goodwin | ||
|  23rd Apr 2017 7:44pm |
| simon70 Member Since: 04 Apr 2017 Location: Shropshire Posts: 9      | I've been doing some phoning around today in relation to the Oil Pressure problem. First to say it's rattly from cold and then quite quickly the revs drop and the engine smooths out. There is a ticking noise. I called a Land Rover specialist who referred me to an LPG specialist, a chap named John. I explained the fact I'd not long bought it and have had the cam box gaskets done. I also explained that one week ago it developed the low oil pressure stop engine warning. I told him it was rattly from cold, he came back with timing chain issues and it looks I've got a big job to get fixed. I was wondering if anybody has got experience of this issue? Can I get away with replacing the tensioner. Any advice would be appreciated. I purchased a warranty from warranty first if anyone has experience of them as well I'd be grateful Simon Goodwin | ||
|  25th Apr 2017 6:52pm |
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8790      | Use the Search on the forum there is good info on the disintergration of the 4.4 timing guide disintergration. There is nothing that can't be fixed with a hammer😜😜
|  25th Apr 2017 7:31pm |
| b348xyx Member Since: 29 Sep 2016 Location: Kent Posts: 319      | just google "M62TU broken timing guides"
|  25th Apr 2017 7:35pm |
| simon70 Member Since: 04 Apr 2017 Location: Shropshire Posts: 9      | I got quoted 8-9 hours labour for the timing chains. I'm going to see this John at Cargas on Thursday. I hope my warranty will pay out Simon Goodwin | ||
|  25th Apr 2017 7:45pm |
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8790      | They usually end up in the sump, could they be blocking the oil pickup? There is nothing that can't be fixed with a hammer😜😜
|  25th Apr 2017 7:46pm |
| 47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048    |
 If you're planning a long term relationship with your FFRR then DON'T buy parts from eBay. They are cheap pattern part that sometimes work for some of the time, sometimes fit but usually with a lot of fettling and never last as long as original parts. | ||
|  25th Apr 2017 11:48pm |
| simon70 Member Since: 04 Apr 2017 Location: Shropshire Posts: 9      | Switch comes from a company called ACP Simon Goodwin | ||
|  26th Apr 2017 1:11am |
| speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727      | Get a genuine BMW / Land Rover switch and oil filter and oil change
|  26th Apr 2017 1:04pm |
| Posting Rules
