Home > Technical (L322) > Heated front screen not working
T24RES
-10oC this morning and the front screen didn't work. Not sure if its worked since i've owned it actually (always used the fbh so far)
Any tips? Ian
Post #43610 26th Dec 2010 9:57am
Only help I can give is that the heater connections are at the sides of the screen under the side trims. It is possible that the screen has been replaced by AutoGlassBreakers and they are not used to complex Range Rover screens and often break them by cutting through the (many) wires behind the rear view mirror or not connecting the heater elements. Rolling Eyes
Post #43611 26th Dec 2010 10:13am
could be the fuse or maybe condensation inside the window shorting the connections or just a RR glitch which means it'll work next time... ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #43612 26th Dec 2010 10:43am
Andy
Only the left side of mine is working now- the right side won't clear. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #43616 26th Dec 2010 12:03pm
T24RES
How do the trims come off? Is there a screw under the air bag symbol ? Ian
Post #43619 26th Dec 2010 1:22pm
CMJ
2015 Range Rover Autobiography TDV6 Santorini Black
I understand the left and right sides are controlled by different units. If only one side works it is usually the unit which has gone. From memory I think it was about £3-400 fix.
Post #43624 26th Dec 2010 2:18pm
dan_uk_1984
The screen is controlled by the ATC ECU, this sends a signal to turn on a relay - this is lives behind the dash (passenger side) You may be able to access it by removing the black end panel (no promises)
But either way, the system is only reliant on three factors, the HEVAC/ATC ECU sending the request (which we should assume it is sending the request) the relay, and the connections to the screen.
Do you leave the A/C on all the time? If not the moisture in the air can attack the bonding of the connection to the screen.
@CMJ - How you could have been quoted £400 to fix some components that don't exist is beyond me, was that by the dealer?!
Dan
Post #43625 26th Dec 2010 3:38pm
CMJ
Yes. Thought we had this done to our last rr however I am now realiably informed it may of been on the one before that which was a P38. Goes to show you should always believe what people post on forums Smile
Post #43646 26th Dec 2010 11:28pm
T24RES
bump, any help please? Ian
Post #43903 29th Dec 2010 9:50pm
dan_uk_1984
You need a copy of the Workshop Manual...
A link to download can be found on our WiKi here: http://www.fullfatrr.com/wiki/RAVE_downloads
Perhaps you could throw a few notes together on what you do so the info can be added to the WiKi for people who have this problem in the future?
Dan
Post #43905 29th Dec 2010 10:11pm
T24RES
- Cheers dan, i've got it now. Bow down However i'm struggling to make it work/open properly
I tried the front screen last night and it worked. Most odd, the only difference was that the AC button was on unlike the other morning.
I'll grab Mrs T24 and see if she can let off some steam to test it again .... Rolling with laughter Ian
Post #43932 30th Dec 2010 11:59am
dan_uk_1984
T24RES wrote:
The only difference was that the AC button was on unlike the other morning.
The AC light should always be on...
The AC is designed to be left on All The Time. This removes excess moisture from the air inside teh car - without it the various ECU's will start to suffer from damp on their PCB's as well as all electrical contacts (like the ones to your screen) will start to furr up increasing electrical resistance.
Post #43958 30th Dec 2010 3:21pm
T24RES
..........but there's a button and i's got to push it Mr. Green Ian
Post #43983 30th Dec 2010 6:10pm
