![]() | Home > In Car Electronics (L322) > Rear Lighter Socket |
DannyH Member Since: 30 Apr 2015 Location: Hull Posts: 221 ![]() ![]() ![]() |
Morning all,
Unfortunately fuse 2 is fine and it's a 5amp. Dan
Sorry, 5A you're right.
Hang on so is the wire feeding in to the fuse board via the black plug or feeding out of the fuse board via the black plug? If it's feeding in to the board then I think the wire might have failed where the other guys has soldered into it that's all I can think of at the moment. Will finish washing the car and do some more investigating. Dan
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1579 ![]() ![]() |
Deleted - misread thread Ron B. VK2OTC
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3268 ![]() ![]() ![]() |
Would be worth re-doing as it may have a dry joint from the previous soldering. John 2008 Stornoway Grey 3.6 Tdv8 Vogue - SOLD 2005 TD6 Java Black Vogue - Written off!! GAP iiD BT-Sold |
Nope no power going to the main plug that the green wire connects into behind the light cluster. Any other fuses relating to this one? Very strange how it's randomly stopped working yet I've not noticed anything else not working Dan
Well I think I need to get my coat. Seems everything works fine when the ignition is fully on so I'm just stupid and assumed the first click of the key would be enough to power everything up like in my previous cars. Sorry for wasting everyone's time. <bows> Dan
It happens |
