![]() | Home > In Car Electronics (L322) > IID Tool Help |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35766 ![]() ![]() |
hopefully you've been doing this with the engine running stu...
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3268 ![]() ![]() ![]() |
When you first activate the iiD tool it oes a backup. You could try restoring to see if that is effective. From the tool manual page 141:
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 ![]() ![]() ![]() |
Yes had the car running, selected a couple of things, activated easy entry, changed the towing part to 13 as I fitted a 13 pin socket and proceeded. Car turned itself off and on and ipad said updating etc.
Still got a D2 |
If I don't have a battery charger as mentioned in the hand manual, will a battery operated jump pack or jump leads from my other car while it's running do the job?
Out of these towing menus, which of them should I have selected to have my 13 pin socket working correctly, e.g. Reversing sensors turning off etc.
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless Iām not at home, in which case Iām somewhere else. Posts: 6819 ![]() ![]() ![]() |
It's probably not related but it was when I changed the wheel size that my CCF file got corrupted. |
Lad Member Since: 12 Oct 2014 Location: Blackburn Posts: 284 ![]() ![]() ![]() |
The device asks you to turn off the car so it can program the ccf. If you don't turn it off, the iid will turn it off for you. After programming the car, it states next time the car is started, start it, switch off, start it and switch off. |
i left it for a while and went back to it, things seem to have sorted themselves out. Not sure yet if any changes have been implemented but everything under control i think!!
Scary, isn't it? |
Yes it is scary, but I don't understand why doing what I did had the results I had. Never mind I'm going to leave it till the weekend now and have my other car attached to it via jump leads to keep the battery charged and do things slowly.
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3850 ![]() ![]() ![]() |
I connect my CTEK charger via the towing socket when playing with iid tool and it seems to keep everything happy. G reg 2.5VM Vogue Portofino red 1991- 1999
@Baltic Blue, how do you connect via the towing socket? do you mean via one of the 7 pin 12s or 12n sockets at the rear? Current: TDV8 (3.6) RRS HSE
Stu,
