Home > Technical (L322) > High idle |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
Well I was a dumb ass today. I know my batts close to the end of it's life as had hdc air suspension probs when I've started it. Had to give my little lad his lunch in the carpark today an made the mistake of putting his DVD on while we fed him. About 20mins later lost sound, HDC INACTIVE, Air suspension inactive, engine fail safe all came up one after another. Tryed to start but batt was dead. Went for some jumpleads an gave one last try after 5mins an she eventually fired into life. This got me out the pooh with the wife but since then I've had a high idle of about 850-900. Normally was about 750.
28th Dec 2010 6:44pm |
I think the car increases revs when the battery voltage falls below a certain level. The Workshop manual certainly "hints" at this although isn't completely explicit.
28th Dec 2010 7:37pm |
Just popped to sainsbury's and back to normal! Think it's as you mentions dan. Will see what happens when I put the new battery in. |
28th Dec 2010 7:53pm |
I wouldn't needlessly replace the battery unless you come out to find it flat. Or you start to get spurious warning messages. It's worth noting that with the ignition on the drain is quite significant, especially if you have it on position II rather than just accessory. Might be worth checking your battery voltage with a multimeter if it does it again. Dan |
28th Dec 2010 8:06pm |
Dan
28th Dec 2010 8:36pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34943 |
that's similar to how i found out my battery was on its way out..i had the windows tinted so the tint man was having the rear windows go up and down to do the tints and when i came to collect ,the battery was dead...i'm pretty sure we're in for more snow and cold weather so now is ideal to change yours... ... - .- -.
28th Dec 2010 8:47pm |
