Home > Technical (L322) > Cleaned the engine bay earth points today - Worth doing...
DeltaC
United Kingdom 2003 Range Rover Vogue 4.4 V8 Buckingham Blue
I have been loathed to disconnect the battery on the RR but today had no choice as I'm removing the fuel pump. While the battery was disconnected, I thought I'd take the opportunity to clean and lube all of the earth points in the engine bay.
Prior to taking the leads off the battery, I followed the instructions in the manual, ie: Disarmed the alarm, opened the load space cover and removed the cover from the nav unit. Then I opened the bonnet and left the car for a few minutes until the nav computer was shut down, then disconnected the earth lead followed by the positive.
There is:
The negative lead from the battery to the body.
A negative connection on the top of the N/S suspension turret.
Two connections behind the header tank N/S.
Two big ones beneath the brain box on the O/S.
Two behind the brain box.
One more for the bonnet on the O/S.
I'd guess the nuts were all installed on the bare body before its painted then the wires are installed during assembly. They were mostly okay but are all dry. A couple were a bit oxidised, the one for the bonnet was loose.
So, if you are fitting a new battery, it may be worth 10 mins with 10mm and 13mm spanners, a tub of Vaseline, a wire brush and give them a quick clean ...
Post #43837 28th Dec 2010 10:54pm
dan_uk_1984
One thing I would say would be to use copper grease instead of Vaseline - as the former is a conductor rather than the latter is an insulator (even though as long as you have metal on metal contact you should be OK.
I have one of these in my arsenal (not to be confused with arsehole as that would be uncomfortable)
It cleans the battery terminal and also the battery clamp.
Dan
Post #43839 28th Dec 2010 11:09pm
DeltaC
I used one of them on the drill for the battery terminals. Smile
I went with the Vaseline instead of the Copper Grease because I find that the Copper Grease can dry out over time although they all got a good dose of aerosol white grease afterwards anyway.
Post #43842 28th Dec 2010 11:32pm
SteveMFr
Site Sponsor
You're missing the female brush, Delta (no puns, now). Plugs right down over the terminal and cleans it up perfectly in no time flat and with no energy expended. I used to have one of these in my toolbox all the time in the US. Got to Europe and have not seen one here - ever. And I have looked.
Don't suppose they're available by mail order, are they Dan?
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #43859 29th Dec 2010 12:10pm
dan_uk_1984
You want the bay:
http://cgi.ebay.co.uk/90MM-BATTERY-POST-AN...2c58762398
Post #43864 29th Dec 2010 1:07pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
Bought and paid for a set. Thanks. Thumbs Up
Post #43872 29th Dec 2010 2:41pm
SteveMFr
Site Sponsor
Me too. Thanks Dan. Even about the same price I remember from 15 yrs ago Shocked - I'm old...
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #43902 29th Dec 2010 9:29pm
DeltaC
Me three !!
Post #43904 29th Dec 2010 10:02pm
dan_uk_1984
I should get commission. As should whoever recommended those luggage nets a few months back!
Post #43906 29th Dec 2010 10:12pm
SteveMFr
Site Sponsor
On 1.04? Laughing
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #43911 30th Dec 2010 12:06am
dan_uk_1984
SteveMFr wrote:
On 1.04? Laughing
Every penny counts when running a RR!
Post #43914 30th Dec 2010 12:20am
T24RES
Nice one dan, i just read the luggage nets thread from your reference and went right in on the bay. Thumbs Up Ian
Post #43931 30th Dec 2010 11:53am
you got a fan dan.....
btw , those luggage nets have gone up a couple of squids since the offer was first posted... ... - .- -.
Post #43944 30th Dec 2010 1:31pm
