Home > Maintenance & Mods (L322) > Drivers heated / cooled seat issue
TOF
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Stornoway Grey
Since purchasing my Vogue SE 2011, i have noticed that the drivers seat heating / cooling only works every now and then. I tried investigating a bit tonight, and noticed that when i turned it on, the media remote for the rear entertainment started beeping, and when i turned the heated seat off, it stopped. During this time that it was beeping, the heated seat was working... It did this a few times, then i got nothing at-all again. No beeping from the remote and no heated seat...
Anyone got any suggestions?
Chris
Post #439200 21st May 2017 9:59pm
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
I've read a lot on the heated seat issue but that's a new one. Can't imagine they are connected within the cars wiring loom but I'm not expert , hopefully someone will have an idea , good luck 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #439209 21st May 2017 11:30pm
JPHC
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
Not sure about the RSE, perhaps just a coincidence or interference?
Common for the heated/cooled seats to fail as one of the pipes inside the seat splits letting out all the hot/cold air and the system shuts itself down as to not overheat. Depending on how you're sat on the seat can sometimes change the behaviour, depending where the split is. Its bad design. Hopefully these links help:
http://www.fullfatrr.com/forum/topic10106.html
http://www.fullfatrr.com/forum/topic28774.html
http://www.fullfatrr.com/forum/topic41063.html
 Jordan
'56 SC 4.2 ‘21-Current
'56 SC 4.2 ‘16-‘18
Post #439247 22nd May 2017 12:03pm
dingg1
yes , just fixed mine last week , if you're a bit porky (me) your back breaks that duct in the lumbar region of the seat back
just bodged mine with tape and now works fine
Post #439257 22nd May 2017 2:06pm
TOF
I have checked with my diagnostic tool and it came up "seat back coolant leak"
Post #440275 31st May 2017 8:56pm
You have a split pipe then sir , but then it was always the most likely answer. 2008 MY Supercharged
Post #440304 1st Jun 2017 6:08am
