![]() | Home > Technical (L322) > Auto Dipping Exterior Mirrors. |
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 ![]() ![]() ![]() |
Hi,
Standard across the range from 02+ |
My wing mirrors are Electrochromatic Glass which darken at night with the same effect as the rear view mirror .... don't think they dip tho |
Thanks Dan, thats what I had hoped - so mine appear not to be working. I will book it in to the dealers in the hope that it's covered under the LR approved warrenty ![]() Gone - Range Rover Supercharged 2006 ![]() |
Do you have a tinted rear window? This screws the light sensor up - speaking from experience |
Yes the back and rear side windows are tinted, but I can see the centre mirror darken if I cover the light sensor on the front of the mirror, but the door mirrors do not change colour.
The mirror detects light behind the car - coming in through the rear window. Without a light source it will not know to dip properly. The light sensor at the front of the mirror is used to verify that it is actually dark outside.
Thanks Dan, that does make sense, I will try the test again tomorrow with a bright torch shining on the rear view mirror, and my finger over the front sensor to trick it into thinking its dark outside. |
I may have a much easier explanation , what colour is the glass in your wing mirrors? Because although the SC came with autodipping morrors they may have been broken at some point and changed with the wrong glass.
I cant see any noticeable tint colour, neither blue or gold.
