Home > Technical (L322) > Auto Dipping Exterior Mirrors.
JustinP
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
Hi,
Does the Vogue SE spec come with auto dipping exterior mirrors?
I've noticed recently that only the interior rear view mirror darkens when there are bright lights behind, so before I book it in to the dealers, how do I confirm my car has dipping exterior mirrors?
I've attempted to check my spec using microcat, but I can't find any reference to the side mirrors, so can one of you who is more knowledgable on mircocat advise me where to look?
Do the exterior mirrors only dip when the outside temperature is above some threshold?
Cheers
Justin
Gone - Range Rover Supercharged 2006
Post #43994 30th Dec 2010 8:53pm
T24RES
MY08 does, the weather doesn't make any difference to the function only the bright lights behind. Only answers part of your Q though. Ian
Post #43997 30th Dec 2010 9:02pm
dan_uk_1984
Standard across the range from 02+
Post #43999 30th Dec 2010 10:00pm
My wing mirrors are Electrochromatic Glass which darken at night with the same effect as the rear view mirror .... don't think they dip tho Thumbs Up
Post #44000 30th Dec 2010 10:08pm
JustinP
Thanks Dan, thats what I had hoped - so mine appear not to be working. I will book it in to the dealers in the hope that it's covered under the LR approved warrenty
Post #44007 30th Dec 2010 11:13pm
dan_uk_1984
Do you have a tinted rear window? This screws the light sensor up - speaking from experience Sad
Post #44014 31st Dec 2010 12:17am
JustinP
Yes the back and rear side windows are tinted, but I can see the centre mirror darken if I cover the light sensor on the front of the mirror, but the door mirrors do not change colour.
Is my test flawed, or would you expect the door mirrors to also darken?
The door mirrors both power fold and adjust, so I don't think its a disconnected connector.
Cheers
Justin
Post #44017 31st Dec 2010 12:27am
dan_uk_1984
The mirror detects light behind the car - coming in through the rear window. Without a light source it will not know to dip properly. The light sensor at the front of the mirror is used to verify that it is actually dark outside.
The problem is the interior mirror is programmed to dim before the side mirrors (to do with the angle of the light) So if the mirror is only getting 50% of the dazzle than it would normally it doesn't think it needs to dim the side mirrors.
Does that make sense? I feel like I used far too many words.
D
Post #44020 31st Dec 2010 12:46am
JustinP
Thanks Dan, that does make sense, I will try the test again tomorrow with a bright torch shining on the rear view mirror, and my finger over the front sensor to trick it into thinking its dark outside.
Post #44021 31st Dec 2010 1:09am
I may have a much easier explanation , what colour is the glass in your wing mirrors? Because although the SC came with autodipping morrors they may have been broken at some point and changed with the wrong glass.
Blues tint is non dipping (and about £70 ) and dipping is a gold tint ( and about £160 ). 2008 MY Supercharged
Post #44033 31st Dec 2010 4:45am
JustinP
I cant see any noticeable tint colour, neither blue or gold.
I will book it in to the dealer next week and ask them to have a look.
Cheers
Justin
Post #44070 31st Dec 2010 2:35pm
