Home > Maintenance & Mods (L322) > Rusting upper tailgate - on the horns of a dilemma.
scotcruz
Scotland 2010 Range Rover HSE TDV8 Zambezi Silver
Cheers Mr T that's very useful. Can I check how sprayed it? was it through the holes on each side? Current:
- L560 Velar HSE R-Dynamic D180
- Peugeot 508 2011 - 2.2 HDi GT
Past:
- FFRR V 2010 - 3.6 TDV8
- Citroen C4 1.6i Petrol
- Mitsubishi Shogun 3.2 DID
- Peugeot 607 2.2 HDi
- Nissan Primera 1.8 SVE
- Honda Civic 1.6 VTEC
Post #440100 30th May 2017 3:19pm
Mr Tee
Scotland 2019 Range Rover SVAutobiography 5.0 SC V8 Waitomo Grey
Yup, nozzle in and offload so to speak, not the full can as it's quite big. I opened the tailgating halfway, just before it goes up by itself, then covered the garage floor with some cardboard to catch the drips, it's a good idea to do it when you don't plan to use the car for the rest of the day, when you close the tailgating, more will come out! I've just had two very small bubbles appearing just to the left of the plastic edge trim at the bottom, nothing has appeared since, unless I use a borescope, no idea if it's working!
Post #440103 30th May 2017 4:46pm
rik
Scotland 2003 Range Rover Vogue 4.4 V8 Bonatti Grey
gave mine a bit of rust treatment and bought a chrome trim that fist over repaired bit . a bit of superglue and wala no rust looks good and cost buttons .
Post #440117 30th May 2017 6:04pm
scotcruz
good shout lads.. gonna get the spray as really keen to stop it from happening.
its clearly a design fault and I cant believe the stealers hide behind the corrosion inspection loophole etc. Shame that previous owner didn't follow it up.. its only out of the 6 years warranty by 6 months so if the previous owner wanted he could have got it sorted under warranty..
if that was me, I would have been over the stealers like a rash. Current:
Past:
Post #440128 30th May 2017 7:33pm
stu
What are the chances of getting the upper tail gate changed under the 6 year corrosion warranty? Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #440130 30th May 2017 7:34pm
scotcruz
Its not unheard of, you need to stick to your guns.
Apparently, you have to have the regular corrosion inspection done by them to before the agree it for you. Current:
Past:
Post #440132 30th May 2017 7:42pm
stu
It just seems funny that over forty years have passed by and they still haven't sorted this out! Every FF I've owned has had this and in this day and age you don't expect rust of a car a few years old. Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #440139 30th May 2017 8:30pm
scotcruz
its ridiculous isn't it.. oh well.. hope it doesn't get worse.. Current:
Past:
Post #440140 30th May 2017 8:35pm
mercs600
England 2002 Range Rover Vogue Td6 Java Black
Had mine done by Car Clinic in Scarborough 3 years ago - first thing I did when I got it back was inject Waxoyl inside the frame. 3 years later and I have very very small bubbling of corrosion on the lower edge but to be fair they did not work on that part. Only issue I have is on top under the glass where they slid the rubber weather strip back on before the paint hardened and as a consequence has developed unsightly rust on the left-hand side. I really need to remove the strip and get it sorted but cannot locate a decent body shop. Bearing in mind every repaint of the upper tailgate incurs an extra cost of new badges - roughly £60 last time ! Shocked
Post #440201 31st May 2017 10:06am
ruffy
scotcruz wrote:
I was thinking the same.. did you use the likes of waxoyl/dinitrol or some sort of rust prevention spray? I assume you apply it from the voids at each end?
I have been using some cheap stuff from Halfrauds in a small bottle with a brush in the lid, good shout in the later post about pumping some decent stuff inside the tailgate, I'll give that a go. 1982 SIII 88ā€ diesel
2007 Discovery 3 V8 S
All gone: 2007 Overfinch TDV8
2007 Supercharged
1991 Vogue SE 3.9 V8
2000 Defender 90 Td5
Post #440238 31st May 2017 4:53pm
Stu, if you get it to the Dealer to inspect then press them you can get it changed with little hassle. I've had 2 done by LR for just a bit of blistering under the lip. Thumbs Up
Not much shouting was needed either! There is nothing that can't be fixed with a hammer😜😜
Post #440358 1st Jun 2017 7:39pm
Boxbrownie
United Kingdom 2008 Range Rover Vogue SE TDV8 Java Black
Haha, exactly what I thought of doing on the 07 we bought today, not going to tackle the rust permanently just yet but going to drown it in ACF-50 (brilliant stuff) then fit a chrome or maybe black as the car is black over the seam, after all it is a FFRR it can get away with a bit of bling hopefully? David
Please let me know if my comments upset you, I may wish to upset you again.
Post #478978 20th May 2018 6:46pm
Grofus
Ireland 2007 Range Rover Vogue TDV8 Zermatt Silver
Just done mine and the arches. The rust bubbles made it look worse than it actually was. Cleaned it back to good metal and found no pin holes or cracks at all. The seam sealer acted as a water trap and it spread from there. All looks good now. The arches were just the usual stone chip damage.
As for the ACF-50. It is good stuff but you might want to tackle the rust first as it might be a pain getting good paint adhesion after its applied. I'm guessing but if it penetrates well it could be hard to remove it for paint. 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #478988 20th May 2018 8:18pm
Boxbrownie
Yes a very valid point, I was going to lather on a load of one of the rust ā€œconverter/killersā€ first to hopefully slow the spread as much as possible and then inject the ACF50, when we get around to fixing it permanently I think it’ll need so much work to really get it right for the future all the temporary stuff will be removed completely, I hope! David
Post #479009 21st May 2018 5:32am
