Home > Technical (L322) > Oil use
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
Oil use
My 2011 vogue se with 106000 miles use`s about 1.5 ltres of oil for every 800miles traveled there is no smoke and the engine runs very smooth with no rattles when cold would this be right.
Post #441019 8th Jun 2017 9:08pm
No.
Mine was using a bit of oil. Leaks found at the bottom end of the engine. One on the dipstick tube/sump drain and one on the passenger side turbo.
Since these have been fixed it hasn't used a drop, was services at the same time and that was 4000 miles ago.
Also check the condition of the water in the expansion, and check the oil/water cooler in the V as these can leak oil into the cooling system. There is nothing that can't be fixed with a hammer😜😜
Post #441022 8th Jun 2017 9:30pm
Tinman
Thanks for the info I will report what I find in daylight
Post #441028 8th Jun 2017 10:32pm
To have a look at the bottom of the dipstick/extraction tube you will
Need to take off the under tray. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #441033 8th Jun 2017 11:28pm
