No.
Mine was using a bit of oil. Leaks found at the bottom end of the engine. One on the dipstick tube/sump drain and one on the passenger side turbo.
Since these have been fixed it hasn't used a drop, was services at the same time and that was 4000 miles ago.
Also check the condition of the water in the expansion, and check the oil/water cooler in the V as these can leak oil into the cooling system. There is nothing that can't be fixed with a hammer😜😜
