Home > Maintenance & Mods (L322) > 3.6 Tdv8 enigne oil leak
TDV8AUTOB
Ireland 2007 Range Rover Autobiography TDV8 Causeway Grey
Hi everyone, I have just joined the form. Ive had a few Range rovers at this stage but this is my first tdv8. I was giving her a general health check this evening and was happy enough with the condition only needing the two front arms replaced on the left corner disks pads and a service. UNTIL i noticed a nastyish enough oil leak. I had checked the jeep over 5,000 miles ago and seen a small oil leak i presumed it was from the turbos and said id look into properly when i was servicing it. 5,000 miles later (95,000) and the bottom of the engine has more oil on it than id rather. My main question is as you can see in the photos it looks like its coming from where the head gasket but is very hard see. Is this a problem on these engines or for those of you who know is it possibly leaking from somewhere else and just ending up there ? I cant seem to post pic but its in my gallery. Thanks in advance
Post #441030 8th Jun 2017 10:58pm
Cant see too much oil on the pic... There is nothing that can't be fixed with a hammer😜😜
Post #441034 8th Jun 2017 11:30pm
TDV8AUTOB
Thsts where i suspect its coming from and traveling dwn to the bottom of the engine.
Post #441035 9th Jun 2017 12:23am
There oil on the oil feed pipe. Get a rag up there and clean it up a bit to see where the oil is coming from.
If it was coming just from th head then how did it get on the oils feed pipe? Wondering if it's the feed pipe leaking not the head just an idea. There is nothing that can't be fixed with a hammer😜😜
Post #441036 9th Jun 2017 12:28am
