![]() | Home > Technical (L322) > TDV8 4.4 oil consumption |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7980 ![]() ![]() ![]() |
I don't need to put any in mine between services. Check your coolant in case your oil cooler is cracked and the oil is now in the coolant....common issue.....
Frans@Yamorna Member Since: 15 Apr 2017 Location: Tzaneen Posts: 147 ![]() ![]() ![]() |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
Frans, may wanna look this thread:
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1422 ![]() ![]() ![]() |
Mine has never needed to be topped up between services (about 50,000 miles now). The electronic level display shows whole divisions and may therefore exaggerate the drop compared with a dipstick and I have found it very sensitive to whether the car is level, and also the temperature of the oil, slight variations can make quite a big difference to what is shown on screen. Only Range Rovers since 1988 |
I want my oil level to be in the middle or one notch up, when engine is cold , so when the engine is at operating temperature oil level is going to be at the full or one notch below. when checking oil level of hot engine wait for 15-20 sec. for sensor to stabilise. |
EmiratesA380 Member Since: 14 Jan 2015 Location: england Posts: 358 ![]() ![]() ![]() |
Unnecessary quote removed
My das 28-32 mpg and your A380 ? |
nino_nino
